Squeaky Clutch Pedal
Old Jan 26, 2010 | 04:34 PM
kplaya186's Avatar
My clutch is rather squeaky some days. Is there a lube point to fix it because it annoys the **** out of me!
Old Jan 26, 2010 | 04:38 PM
09CobaltLT's Avatar
yeah same here lol bump for an answer
Old Jan 26, 2010 | 06:01 PM
BRHumbert's Avatar
Yep, same here. I think there was a Thread about this not to long ago.
Old Jan 26, 2010 | 06:02 PM
ls1fbody's Avatar
Haz l33t wheelz.
Oil can points.
Old Jan 26, 2010 | 09:19 PM
sstaton1983's Avatar
i thought i was the only one lol.
Old Jan 26, 2010 | 09:21 PM
hatrickstu's Avatar
pee on it.
Old Jan 26, 2010 | 10:36 PM
Whtbolttc09's Avatar
Mine is squeaky too. When my car was at the dealership right after Christmas I had them look at it and they said they put some grease on it. It stopped for a couple days but that was it. Would also like to know how to solve the problem if it can even be solved.
Old Jan 26, 2010 | 11:48 PM
philip420's Avatar
Cool
I have the same problem and know how to fix it turn ur radio up thes cars make alot of rattles and ****....
Old Jan 27, 2010 | 01:38 AM
Psytocrophic's Avatar
Yeah i have it too. Franky a squeeky clutch pedal is the least of my worries. I dont notice it anymore its not even a big deal. my brakes squeeking pisses me off on the other hand. ******* dealer wont change my rotors. GM TECH: "you brake to aggressively" Me: "**** YOU HOE AINT KNOW ME!"
Old Jan 27, 2010 | 01:40 AM
1badBlueberrySC's Avatar
Yup same issue here.... mine has been greased back up and it came back... it's annoying as ****!
elecblue06's Avatar
clutch master cylinder
Old Jan 27, 2010 | 01:56 AM
usdm08's Avatar
same problem here????
Old Jan 27, 2010 | 03:03 AM
SSlobalt's Avatar
That's funny; my Cobalt is the only standard I have ever owned that didn't have a squeaky clutch pedal.
btw: The grammar in this thread is horrible. You guys need to get it together.
Old Jan 27, 2010 | 03:06 AM
Geo_SS's Avatar
wow mines been like that for 2 months already..kinda forget about it but then it comes back
Old Jan 27, 2010 | 03:14 AM
06CobaltSS635SC's Avatar
got the same problem except mine only does it when its really cold out. Dunno why that is....
Old Jan 27, 2010 | 03:17 AM
SSlobalt's Avatar
Cold contracts metal, which makes strange **** happen in situations where tolerances are tight.
Old Jan 27, 2010 | 03:23 AM
Gotcha... Maybe I should move to Austin ; getting sick of the snow and cold.....
Old Jan 27, 2010 | 03:24 AM
SSlobalt's Avatar
It's a freezing 63 degrees here.
Old Jan 27, 2010 | 11:43 AM
Cavalierssr's Avatar
I had the same problem, all I did was spray some WD 40 near the top of the pedal, worked the clutch and sprayed some more - solved the problem for me.
Old Jan 27, 2010 | 11:46 AM
pnshmntMMA's Avatar
its annoying, i had it too, has to do with temp and humidity. it dissapeared as soon as the cool dry weather hit. was BAD in august september and oct. lube could help, so would earplugs
Old Jan 27, 2010 | 12:02 PM
coffeeslug's Avatar
Bingo
Old Jan 27, 2010 | 02:23 PM
wantedSS/TC's Avatar
I did the same. Never came back.
Old Jan 27, 2010 | 04:28 PM
kplaya186's Avatar
Originally Posted by hatrickstu
pee on it.
Tried this first (since it was free), but it was difficult to aim up there and just froze up due to the low temps in Michigan. Next, I tried the WD-40, and it worked just fine!
Old Jan 27, 2010 | 08:00 PM
Jointheriot's Avatar
Dealer said to me "they are brand new brakes they dont squeek" they ******* squeeked as i pulled out of the garage..
Old Jan 28, 2010 | 03:49 PM
pnshmntMMA's Avatar
GM screwed me on the brakes too. um ******* dealer, the front brakes would be shot if i was aggressive you retard. he said i was drifting...yea ok PERFECT tires and shot REAR brakes? sumbudy is a wittle weetawded. i just bought 4 brembo rotors and hawk hps brakepads. problem solved. **** gm. stockers would to it again and again, but remember to get the caliper pins lubed!!! thats the issue
