Still thinking of getting tune,....1 more question....
Yes you can flash your stock tune back to your car with the trifecta cable.
Yeah on this note, you can also flash back to stock with HP Tuners since stock tunes are available at hptuners.com. If you dont own it, you can either find someone who has your entire make/model year licensed (free!), or pay $100 for someone to license your vehicle on their device.
You wont be able to go back to the trifecta tune though, since HPT cant read/save it.
I personally bought the trifecta cable since a couple of friends are trifecta tuned. They come to me and I flash them back and forth for free.
Sherm420s car was running great until he got tuned by Trifecta then it started misfiring and was running a 9.0 A/F at WOT. Something is broken now on his car hopefully the dealer will find the cause of the misfires. I hope he does not have cracked ring lands. I have logs showing a ton of misfires and compressor surge that they cause at WOT. His A/F is dead on according to my logs but it is knocking on close to stock timing on 93 octane.
if you're going to go trifecta it's best to just get the hide a tune.. then theres no reason for reflashing
and term yu fail to mention the fact that his charge pipiing had a hole in it causing issues as well as his intake and he was having misfires prior to the tune ...
also you could also buy a cable for yourself so you can pay a 1 time fee and reflash/ update with vince at any time
hptuners cant read the trifecta tunes.. HOWEVER they can write over trifecta tunes.. and make changes to that tune.. so if you wanted you could get a hybrid tune.. with trifectas infiniboost / switch tune settings and bumped fuel pressure then you can go in and tune it like regular HPtuners wont be able to write/ read that custom trifecta code but your custom tune will still work giving you the best of all worlds
Cable
That little hole was only a small issue. The Hahn intake makes the car run leaner than normal not richer. The car was running fine until right after he got tuned then it immediately started misfiring badly and running mega rich. Something is definately broken on his car but it was not that way prior to his Trifecta tune. That was my point.
he stated in his threads that he brought it to the dealership before he got it tuned...
He barely had the trifecta tune on his car. He has been running your tune much longer, and you blame the trifecta tune for his current problem.
