Ticking Noise
Old Jul 12, 2008 | 08:10 PM
hayabusa's Avatar
Ticking Noise
Does the new turbo motor make a metal ticking sound when you left the hood and listen to the car idling. I know from my brothers sky red line the motor clicks on and off like a switch or something i did hear that which i know is normal. But when the car idle i though the motor was kind of noisy making like metel to metel valve chatter the salesmen said that was normal for this engine.
Sounded like upper valve noise kind of noisy for a new car . But the car was very smooth and quiet when i was driving and fast.
Old Jul 12, 2008 | 08:44 PM
stryder's Avatar
the sound you hear is the direct injection.
Old Jul 12, 2008 | 09:14 PM
Tomtwtwtw's Avatar
Yes, the injectors are loud as ****. Sound insulation and other noise is the reason you can't hear it while driving normally.
Old Jul 12, 2008 | 09:19 PM
hayabusa's Avatar
the clock tick was fine i know of this sound from my brothers red line. i thought i heard like valve chatter noise coming from the top end under the covers. so let me see if i understand are you saying the di makes the chatter noise so the motor makes like two different noises.
Old Jul 12, 2008 | 09:22 PM
yel-low's Avatar
yes that is correct the direct injected is the noise its because of the fuel pressure it has
Old Jul 13, 2008 | 04:58 PM
stryder's Avatar
right around 2000 psi lol crazyness
Old Jul 13, 2008 | 05:53 PM
Mr_Slobalt's Avatar
yep.
Old Jul 15, 2008 | 02:56 AM
IsItFast?'s Avatar
But only under certain circumstances. Its not 2000psi at idle. You should be hearing two distinct sounds - one more of a chatter - this is the injectors cycling, and the other about every second going tick, tick, tick - this is the high pressure cam-driven fuel pump bypassing. That sound should go away when you rev the engine.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
