tpms sensor
tpms sensor
last night 2 out of 4 tpms sensors apparently took a crap...i know the tires arent flat (obviously) but just wanting to make sure that its fine to ignore em for a lil and what would cause em to fail? im assuming the roads bc the roads where i live are horrible and im gonna guess pot holes and bumps and all can cause this problem?
i hate tpms sensors...theyre a pain...ive never had and this is the reason why...plus youd have to be a moron to not notice you have a flat...why d we need sensors to tell us that...
It was made mandatory not for safety reasons but for fuel mileage. Properly inflated tires get better mpg contributing to less emissions.
But yes they are stupid. It just shows how lazy people have become. When was the last time you saw someone check their oil at a fill up? Why bother when you have light...
We have them because people are too stupid to notice or check therefore the govt requires them.
robk
What's worse, is that our system is freaking annoying...
My brother's '09 SRT4 has a little light (not even half the size as ours) that goes on;
no blinking, no turning it off to have it start flashing again... ugg.
I had read that Vince was looking into turning off the warnings associated with the TPMS, but I never heard if this was completed/offered...
I believe the batteries in the TPMS sensors are supposed to last 6-8 years. Corrosion is a common failure. A lot I've seen then get over tightened causing excess pressure between the wheel and sensor causing the plastic body of the sensor to crack. TBH failure to road impact is extremely unlikely but not impossible.
I forgot to state the obvious also. Improper installation is a huge killer to these too. If you pop the bead if the tire incorrectly or don't use enough lube ; hell even during removal if you pry in the wrong spot.
In a perfect world you get punished for stupidity not rewarded.
Yup mine does the same on and off every now and then, never have any issues with the ones in my Yukon though don't know why the balt ones are crappy maybe the lower profile tires do have something to do with it
Sl0wbaltSS
Nov 21, 2018 11:11 PM
royce777
Sep 28, 2015 07:11 AM
