TSB/Recall for the LNF engine oil leak?
Are there any official TSB/Recall for the LNF engine oil leak?
It's been discussed in these few threads...
Original post
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/intake-camshaft-sensor-issue-153670/
Grimpster's analysis
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/oil-leak-analysis-my-09-tc-186430/
Grimpster's how-to
https://www.cobaltss.net/forums/show...78#post4344478
damn.. I just found it... is this it??
https://www.cobaltss.net/forums/problems-service-maintenance-69/gm-pip4718-oil-leak-front-crankshaft-seal-area-2008-09-a-190914/
Service Information
Home Publications Number Search New Bulletins Bulletin Search Feedback Help
Document ID: 2355311
#PIP4718: Oil Leak At Front Crankshaft Seal Area 2008-09 Ecotec (RPOs - LAP lAT LE5 LE8 LE9 LNF) - (Oct 1, 2009)
Subject: Oil Leak at Front Crankshaft Seal Area 2008-09 Ecotec (RPO- LAP LAT LE5 LE8 LE9 LNF)
Models: 2008-2009 Chevrolet Cobalt SS
2008-2009 Chevrolet HHR
2008-2009 Chevrolet HHR SS
2008-2009 Chevrolet Malibu
2008-2009 Pontiac G5
2008-2009 Pontiac G6
2006-2009 Pontiac Pursuit (Canada Only)
2008-2009 Saturn Aura
2008-2009 Saturn Vue
Equipped with the following engines:
2008-2009 2.0L (RPO LNF)
2009 2.2L (RPO LAP)
2009 2.2L (RPO LE8)
2008-2009 2.4L (RPO LE5/LE9/LAT)
posted by rukkee
Original post
Grimpster's how-to
Service Information
2009 2.2L (RPO LAP)
2009 2.2L (RPO LE8)
posted by rukkee
If your under warranty bring it in if it's leaking . A TSB is a bulliten that helps tech's fix common issues when diagnosing vehicle's , they are not recall's . The document that is listed above is a Preliminary Information document , it's not a TSB yet . A PI is like advise from GM to help techs do their job .
Sorry for the confusion , I post these just so people can have a heads up so they keep an eye out incase they develop a problem . Most of time a tsb will only effect a small number of cars built during a certain period of time.
I have the leak mentioned in those threads I posted above... I printed some pictures
to show the dealer this coming Friday.. hopefully they will fix it.
Here is another place to look for an oil leak.
Service Information 2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 2195055
#08-06-01-017C: EI08224 - 2.0L LNF, 2.2L L61, 2.4L LE5 Engine Oil Leak (Repair Leak) - (Sep 22, 2008)
Subject: EI08224 - 2.0L LNF, 2.2L L61, 2.4L LE5 Engine Oil Leak (Repair Leak)
Models: 2008-2009 Chevrolet Cobalt, HHR, Malibu
2008-2009 Chevrolet Captiva Sport (Built in Ramos Arizpe, S in VIN Position 11)
2008-2009 Pontiac G5, G6, Solstice
2008-2009 Saturn Aura, SKY, VUE
2008-2009 Opel GT
2008 Daewoo G2X
with 2.0L, 2.2L or 2.4L Engine (VINs X, D, B - RPOs LNF, L61, LE5)
This bulletin is being revised to end the need for engineering information and provide a correction procedure. Please discard Corporate Bulletin Number 08-06-01-017B (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment about an engine oil leak.
Cause
Engineering has determined the cause of some engine oil leaks may be attributed to bedplate porosity at the rear A/C bolt hole mounting bracket.
Correction
DO NOT REPLACE THE ENGINE.
If the engine oil leak is diagnosed as coming from the rear A/C bolt hole mounting bracket, use the following repair procedure to correct the condition. The oil leak in this area is coming from a non-pressurized hole.
•After the engine has cooled, clean the existing oil out of the hole and off the head of the bolt using a low VOC brake cleaner (P/N 12378392 or equivalent).
•Apply a Teflon® pipe thread sealant (P/N 12346004 -- LOCTITE™ 565 or equivalent) to the bolt and reinstall.
Warranty Information
For vehicles with an oil leak in the A/C compressor bracket area, use the labor operation number listed below.
Labor Operation
Description
Labor Time
J7539*
Engine Oil Leak Repair
0.2 hr
*This is a unique labor operation number for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
2008-2009 Opel GT
2008 Daewoo G2X
Condition
Cause
Correction
Labor Operation
Description
Labor Time
J7539*
0.2 hr
