Turbo problem question
Short ram intakes always require tuning cold air sometimes not. That lower cold pipe is a mess and I would start there personally because if nothing else it has to be checked even if it's not the root cause. If you had go tuners to could do some logs and find out what is reading correctly and what is changing after 15 minutes.
armcclure (01-09-2019)
Thank you for the link! I will have to save up for that, for the mean time me and the guy at work sanded the spot down and put fast plastic repair and it held and weird thing is I thought the stock ss turbo ran like 17 psi? I hit 30 psi... I’m hoping the previous guy that had it didn’t **** with the stock turbo and just upgraded it But thank all you guys for the support and input, means a lot!
Yea it’s all fixed for now and that nice fellow sent me a link for a zzp intercooler, 400 bucks though so might be a little bit before I get it but I’m happy it’s holding boost for now
