turbo stopped spinning
I hope i'm posting in the right section.
I have a 08 Cobalt SS. Stock other than a K&N Typhoon intake. I took off from a red light the other day, maybe 3/4 throttle, and all of a sudden it felt like I hit a wall. I let off the gas immediately and resume driving and notice I have no boost. My boost gauge would only rise to 0 psi. Car ran normally as long as i drove like a grandpa. No lights or codes. So i figured boost leak or turbo. Well i put the car on a lift and check all the piping out. Everything looks good. No noticeable damage as far as i can tell. I remove the intake and look into the turbo with a mirror and flashlight. It doesn't look bad so I check for shaft play. When I do I notice the shaft wont spin or move at all. its just stuck. Anyone ever have this happen before? Any idea what caused this to happen? Guess i better start looking for a turbo :( |
your bearing is most likely seized up. definitely need a new turbo. make sure you look at lines and all that to make sure its getting oil before you put a new one in, or you will have the same issue. most likely just died of old age and abuse.
Might need to check the MAF |
Originally Posted by HellboundChevy
(Post 7705144)
How is the oil level and quality? Sounds like the turbo may have been starved of lubrication.
Many vehicles also incorporate a mesh filter in the turbocharger oil feed; check the block side, banjo bolt, and line. If you can't see clearly through any of the passages, I would recommend replacing the component. |
about half the cars we have come in have clogged oil drain lines.
Seriously? That's a pretty big line.
(Post 7706236)
