turbo stopped spinning
Old 12-09-2018, 10:53 PM
Liked 0 Times in 0 Posts
I hope i'm posting in the right section.
I have a 08 Cobalt SS. Stock other than a K&N Typhoon intake. I took off from a red light the other day, maybe 3/4 throttle, and all of a sudden it felt like I hit a wall. I let off the gas immediately and resume driving and notice I have no boost. My boost gauge would only rise to 0 psi. Car ran normally as long as i drove like a grandpa. No lights or codes. So i figured boost leak or turbo. Well i put the car on a lift and check all the piping out. Everything looks good. No noticeable damage as far as i can tell. I remove the intake and look into the turbo with a mirror and flashlight. It doesn't look bad so I check for shaft play. When I do I notice the shaft wont spin or move at all. its just stuck. Anyone ever have this happen before? Any idea what caused this to happen? Guess i better start looking for a turbo
CaptxKirk is offline
Old 12-10-2018, 07:08 PM
Liked 112 Times in 100 Posts
your bearing is most likely seized up. definitely need a new turbo. make sure you look at lines and all that to make sure its getting oil before you put a new one in, or you will have the same issue. most likely just died of old age and abuse.
tomj77 is offline
Old 12-31-2018, 11:25 PM
Liked 1 Time in 1 Post
Might need to check the MAF
HellboundChevy is offline
Old 01-06-2019, 02:03 AM
why on earth would he check maf if the turbo is seized? he needs a new turbo
tomj77 is offline
Old 01-21-2019, 07:25 PM
How is the oil level and quality? Sounds like the turbo may have been starved of lubrication.
Many vehicles also incorporate a mesh filter in the turbocharger oil feed; check the block side, banjo bolt, and line. If you can't see clearly through any of the passages, I would recommend replacing the component.
Sport Red LNF is offline
Old 01-22-2019, 04:43 PM
Liked 19 Times in 16 Posts
about half the cars we have come in have clogged oil drain lines.
armcclure is offline
Old 01-22-2019, 08:55 PM
Liked 269 Times in 254 Posts
Seriously? That's a pretty big line.
63 Nova SS is offline
Old 01-22-2019, 11:43 PM
Oil sludge is the devil.
Area47
03-05-2009 04:12 PM
SSdan
Nitrous Oxide
31
11-03-2008 10:27 PM
NoBalt123
06-28-2008 12:55 PM
D4u2s0t
01-06-2007 10:47 AM
Ern
06-05-2006 09:35 AM
Quick Reply: turbo stopped spinning
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
