Walnut blasting in Metro Atlanta - Cobalt SS Network
Thread Tools Search this Thread
Old 10-12-2017, 11:25 AM   #1
Hey. My '10 SS/TC is has over 82k miles in it now and I would like to get the intake valves blasted clean. Anyone know of someone capable/trustworthy of doing this in Metro Atlanta? Any help is appreciated.
TotalChaos is offline   Reply With Quote
Old 10-12-2017, 11:30 AM   #2
exninja's Avatar
Have you taken the IM off before? If so, you can do this yourself. It's not that hard, just takes some time. Save some $$.
exninja is offline   Reply With Quote
Old 10-12-2017, 01:53 PM   #3
Quote:
We have an intake removal guide and valve cleaning guide. Both very useful.
Oh and you can use GM upper engine cleaner and soak the valves instead of walnut blasting.
There are much harder jobs to do than this. It's just time consuming.
umrdyldo is offline   Reply With Quote
Old 10-12-2017, 05:04 PM   #4
I’m going to assume you have access to a vacuum and compressor. You can pick up a blaster for $15-$50 which will work just fine. Media is $50 for a huge bag and if you don’t want a mess you can just buy the adapter off ecstuning.com. It’s really easy to do it just takes a while. Some wire brushes and picks will help as well.
cobaltssdude420 is offline   Reply With Quote
Old 10-12-2017, 05:05 PM   #5
Buying the adapter is definitely a better option compared to prepping it with plastic drop sheets
Old 10-12-2017, 05:08 PM   #6
Quote:
Why are all of your posts half written in High Valyrian?
double clutch is offline   Reply With Quote
Old 10-12-2017, 05:18 PM   #7
I had to look that up to see if it was a language or form of writing lol. What do you mean?
Old 10-12-2017, 05:27 PM   #8
exninja's Avatar
Your apostrophes come out funky
Old 10-12-2017, 05:50 PM   #9
Thanks lol. Ill make sure i dont use any
Old 10-13-2017, 02:22 PM   #10
Yea.....I don't have a compressor. I guess I can go to HF and pick one up. I wasn't in the mood to invest in any more tools even though I prefer to do it myself. I guess I'll start picking up the necessary items to get this done.
Thanks
Old 10-13-2017, 02:29 PM   #11
exninja's Avatar
You can have really good results with chemicals, brushes, and picks if you don't want to spend the coin on a compressor. OTOH, this can be a good excuse to buy one. Check craigslist also.
Old 10-13-2017, 11:39 PM   #12
I m going to assume you have access to a vacuum and compressor. You can pick up a blaster for $15-$50 which will work just fine. Media is $50 for a huge bag and if you don t want a mess you can just buy the adapter off ecstuning.com. It s really easy to do it just takes a while. Some wire brushes and picks will help as well.
what car is the adapter for I don't see a cobalt on there website i was going to use a radiator hose but if the adapter is not to much I will buy it can anyone give me part#
Dave8699 is offline   Reply With Quote
Old 10-14-2017, 07:29 AM   #13
https://www.ecstuning.com/Search/Sit...ction_Adapter/
Not sure if that link turns out all wonky in here but basically just type in extraction adapter and those 2 parts are what you need. The adapter that goes in the valve port is slightly too small but once you hook up the vacuum, the suction holds it in place.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
