At what rpm are you hitting max boost with gms1
So I've had my second ss/tc sedan for about 6 monts now and it came with a gms1 tune, I've heard of people hitting 21 psi and holding but was wondering at what rpm are you supposed to be at 21 psi. I hit 18 psi and then it bumps up to 21 over 4k rpm and then falls off at about 5500 rpm
What I mean is that just like the stock tuning, GMS1 will vary boost (not sure what max is ) depending upon atmospheric conditions to hit it's desired power level.
So, some days you might see peaks of 22, some days 20, etc.
That being said, this morning I did a second gear romp and it seemed like it was holding around 21 for as long as I was in the gas - I was watching the gauge and not so much the RPM's so I am not sure where I was when I let off.
I am sure others will chime in on this .
Enjoy the sedan !!
Britt
Enjoy the sedan !!
Britt
i think its our turbos running out of breath up top. i have a HPTune and i spike at 27lbs and falls off over 5k and settles at 21lbs, do you have an aftermarket IC? my boy had a stock intercooler holding 25lbs and once we installed his turbo XS IC he now has the issue we have.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
