10 psi max
Old 04-03-2013, 05:40 PM
Shortbus's Avatar
10 psi max
First off heres the info on the car
2008 cobalt ss/tc
8,000 miles
k&n sri
zzp catless d/p
stock tune
heres the issue
Just recently i have been having a issue with boost, No CEL, and no codes on the car. When i first put the sri on the car it ran fine, bpv sounded like it was opening and closing properly. Now weeks later it is sounding like the bpv is not working properly, it will spool but not make a lot of boost, 10-12 psi MAX. This usually happens when the car is warmed up also, doesnt do it around 100* but around normal driving temps. To me it sounds like the bpv is opening when it shouldn't be. I would like to get this figured out before i do the zfr and other mods. Any ideas? Maybe the car doesnt like the k&n on stock tune?
Old 04-03-2013, 06:23 PM
AARON-SS-TC's Avatar
wait a minute, you have 8,000 miles on your car? damn...lol
Old 04-03-2013, 07:10 PM
Shortbus's Avatar
Haha yea, lucky find. It's pretty much brand new.
Old 04-04-2013, 07:59 AM
Shortbus's Avatar
Problem solved, cleaned maf and changed the position of the k&n filter.
Old 04-04-2013, 12:27 PM
Scooooooore...with 8k miles, i couldnt imagine anything major wrong with it
Old 04-04-2013, 12:35 PM
Shortbus's Avatar
Same thing I was thinking, the first 6k of this car were babied by a old guy.
Old 04-04-2013, 12:37 PM
Terminator2's Avatar
And you know he never tuned or modded the car more than likely. What a find I want another SS/TC but I want a sedan this time.
Old 04-05-2013, 07:44 AM
Shortbus's Avatar
Very lucky find sir!
Problem is back, turbo just makes a whistle sound, low boost. Bpv is not functioning I believe, but still no CEL wtf!
Old 04-05-2013, 11:14 AM
rukkee's Avatar
I had a similar problem when mine was new .... ended up being the wastegate actuator had a bad connection . Plugged the connector in all the way and was good to go.
Old 04-05-2013, 11:23 AM
Shortbus's Avatar
Hm, ill have to check it out. Thanks!
Old 04-05-2013, 11:26 AM
Check for leaks. It takes a big leak to trigger a rich code or MAF out of range code.
Old 04-05-2013, 12:03 PM
Shortbus's Avatar
Ill check, the weird thing is yesterday it ran fine, then the next low boost again. Wouldn't a leak be constant?
Old 04-05-2013, 12:13 PM
Maccoy316's Avatar
I had the same problem even with a Forge BPV. New tune and cleaned the MAF sensor and it's good to go. Haven't had the problem in a long time.
Old 04-05-2013, 12:29 PM
Shortbus's Avatar
The other day, I changed the position of the k&n filter and cleaned maf. That worked for a little while then it went back to doing it, still does it on my new tune i got yesterday, no changes from stock tune to new tune.
Old 04-05-2013, 12:40 PM
Check the WG rod but you have to get under the car to check it. Check BPV diaphram to make sure it is not ripped.
Old 04-05-2013, 12:51 PM
Shortbus's Avatar
Thanks, ill check them!
Old 04-05-2013, 05:04 PM
Shortbus's Avatar
Now randomly runs fine again, bpv working wtf!? Then when it gets to operating temp same crap, low boost bpv not working.
Old 04-05-2013, 05:15 PM
BaDAssCoBalt08's Avatar
have you taken it to the dealer or a professional yet?
Old 04-05-2013, 05:19 PM
alerosaint's Avatar
These cars have the weirdest intermittent issues! Smh... I have a similar problem.. My car sometimes dump boost randomly a one minute
And pulls fine to 26 psi the next
Old 04-05-2013, 05:48 PM
Shortbus's Avatar
Same thing it's doing, I'm getting frustrated at this point! Currently have the car in the air.
Old 04-05-2013, 06:25 PM
Shortbus's Avatar
Not taking it to a dealer.
Old 04-05-2013, 07:31 PM
Could be a dirty boost solenoid or in the case of a car running 26 psi p0106 or other boost related code may not be disabled in the tune.
Old 04-05-2013, 08:26 PM
alerosaint's Avatar
Funny thing like shortbus, I am not getting a code. I would WOT in 3rd 26 psi shift, then wot in 4th and get 20psi......try it again get 26 psi in 3rd, shift then get 26 psi in 4th. I am getting ready to throw a boost solenoid at it. P0106 is enabled tho
Old 04-05-2013, 09:41 PM
Turn p0106 off and see if it stops. If not clean the boost solenoid out with carb cleaner and check the plug as well.
Old 04-05-2013, 10:12 PM
Shortbus's Avatar
Where exactly is the solenoid located?
Quick Reply: 10 psi max
