2009 SS/TC Sedan Build Thread - Lots of pics
Installed blue lug nuts, they actually match realllly well.
did some sanding last week and some touch up paint.
Lots of scratches gone. we missed a few though!
Ty man
Better pic
Better pic
That car is so clean man.. What a transformation!!
So did you wet sand/polish the whole door? Or just the spots with scratches? Also, did you do any waxes or sealants over the car?
Thank you! Mostly the scratches. I forget what doors were done fully. My buddy did it, he works in a body shop
Thanks! Currently trying to figure out why my car is leaning out above 20psi lol
Figured out the misfire at 23psi... it was shitty NGK plugs. I put delcos back in and it runs perfect now. Just ironing out the tune.
Got Powell v3, stage 1 maps, and hawk HPS pads/rotors for the front. Should have that done this week.
maybe black friday ill get the ZZP catback/dp!
ThoR294 (11-22-2016)
Will do that next time.
Still need to do pads/v3. ugh no time!
#36
No more whip antenna. Had to replace the base of course. I did this 2 weeks to my g5 before I sold it lol. Had to buy the same stuff again!
#37
Last week:
Installed Stage 1 MAP sensors
Hawk HPS Pads + New rotors up front
New LCA bushings up front from ZZP
did a trans drail/fill with the GM fluid that smells like bourbon...
earl change.
Still haven't done Powell V3 or valve cleaning. I know I'm slacking.
earl change.
zeeky420 (01-18-2017)
#39
I got LED tail lights for the car too. No resistor in the box so I'm waiting the resistors in the mail before installing. You'll get more pictures then! Also, needs a real bath.
RF wheel still a little bent... it took 6 ounces of weight on the machine and it's got a wobble. Trying to find a new straight one.
#41
Were the scratches bad enough on your car that it really required wet sanding and couldn't be taken down with a buffing compound and some polishing? Wet sanding should probably be followed up with more clear coat since you could have taken quite a bit off.
ThoR294 (03-08-2017)
#44
I put it on the front because I like ***** on the chin
I know, it is sad. I spanked tons of subarus and had my fun. I need to focus on the trans am tho. Don't worry I'll have another LNF esq auto car before the year ends
