Anybody used ZZP's motor trans mounts?
Seeing if anyone on this forum has used or thought about going to ZZP's transmounts. I never hear much about the mounts and don't know how different they are compare to other mounts like TTR, OTTP, and Avid. Thanks.
http://www.zzperformance.com/cobalt_...1148&catid=187 and http://www.zzperformance.com/cobalt_...1147&catid=187 |
Originally Posted by efactor
(Post 5381403)
Cobalt & Ion ---> ZZ Performance and Cobalt & Ion ---> ZZ Performance after you get any aftermarket mounts installed - get the wheels aligned, as a preventive measure, it will prevent premature tire wear.. stock factory mount are soft which the wheels have +/- toe/camber from the factory, installing semi-solid mounts the wheels will have -/+ toe/camber.. getting them aligned will help you drive straight down the road.. |
Originally Posted by gone_in_10_sec
(Post 5381840)
I have both of the ZZP mounts, they're great no problems at all! I've put 16k miles on them..
after you get any aftermarket mounts installed - get the wheels aligned, as a preventive measure, it will prevent premature tire wear.. stock factory mount are soft which the wheels have +/- toe/camber from the factory, installing semi-solid mounts the wheels will have -/+ toe/camber.. getting them aligned will help you drive straight down the road.. did you have wheel hop before? y did you buy them? I want zzp's but i dont konw if they are worth it |
We use a rubber bushing on the trans mounts so they should not increase vibration. We have developed them on our Cobalts and our cars have no wheel hop. Currently they've helped get our track 60' times down to 1.6's in Ryan and Matt's car and that's the best on the forums. (Ryan also did 1.5's but that was with wheelie bars)
You will get the same results by installing poly inserts or installing the entire aftermarket mount. I just a manner of direct bolt in or not installation.
doesnt ryans car just have your upper mount engine and lnf lower trans mounts?
Originally Posted by beast10007
(Post 5382093)
how are the vibs in the car now?
did you have wheel hop before? y did you buy them? I want zzp's but i dont konw if they are worth it I had wheel hop when I first got the car, but from not knowing how to drive her, but once I learn how to drive her.. never had wheelhop once the mounts were installed.. I got the mounts to get more traction to the street, for me they were a best buy and worth every penny. |
Originally Posted by whyyoumadson?
(Post 5384626)
(Post 5384733)
The vibration is min but with the solid mounts its normal.
I had wheel hop when I first got the car, but from not knowing how to drive her, but once I learn how to drive her.. never had wheelhop once the mounts were installed.. I got the mounts to get more traction to the street, for me they were a best buy and worth every penny. I do know how to drive and I never get wheel hop with my cobalt, now my old eclipse I got some major wheel hop tho. so you said mounts give you more traction on the street? how so does you car now hook up in 2nd or do you have less TQ steer? |
(Post 5384736)
I believe transmounts on there.
(Post 5386254)
just saying i heard differently so a correction would be nice. i run powells mounts. best out.
yes BUT powell makes the mounts for them. but rumor has it powell NO LONGER makes the mounts for ottp and ottp is on their own with a copy or something similar. unsure of the details. like i said its something i heard along the grape vine.
(Post 5386780)
Originally Posted by blackvette101
(Post 5387075)
but isn't ttr the same mount only with polyurethane instead of rubber.
(Post 5387075)
sorry to threadjack but do you guys no if there are any solid metal mounts
well this concludes this thread. Guess the two top choices are ZZP or OTTP then. TTR just needs to do some R&D on some rubber bushings and get rid of poly.
(Post 5389413)
(Post 5388649)
