Limp mode Cels Help LNF
P0090 - Fuel Pressure Regulator Control Circuit (SES, Pending, Current, History)
P0122 - Throttle/Pedal Position Sensor A Circuit Low (Current, Old)
P0193 - Fuel Rail Pressure Sensor A Circuit High (SES, Current, History)
P0223 - Throttle/Pedal Position Sensor/Switch B Circuit High (Current, Old)
Just started doing it out of the clear blue sky. Since I had a pile of new parts. I changed the complete fuel rail and HPFP as well as the gas pedel. nothing. Im assuming a bad wire but which one. Didnt change the TB but have a new one to try
Its been a long time since Ive played with the lnf, I had the issue with the tps once when the solenoid that is on the turbo had a broken wire, I also had changed out the sensors and gas pedal and found the wire ended up being broke. Check it out.
