Boost leak tested my car ...
Just thought id share this with everyone.. I boost leak tested my car the other day, turns out I had a small leak on my coldside IC pipe (zzp). It was leaking from the MAF relocate spot. The little plastic piece they send you to block off the flange was leaking.
I ended up having a roll of cork sealer from autozone, cut out a piece shaped to the MAF flange and bolted it back up... Doesn't leak now.
Just a little fix I thought id share, im sure the leak wasn't enough to loose power or throw anything off. but just a little piece of mind.
Turbo Johnny
Feb 21, 2019 09:41 AM
