Brand new turbo, what's it need?
Do I need to oil it or anything before installing it because it's brand new and nothing on it. It's a stock k04 and where the two bolts go in between the compresser side and induction side....they arentthere and am I suppose to oil it there?
um im pretty sure u just install it and ur car will do the rest with the oiling
if you can realistically pour some oil into the turbo when its installed after you install the drain so it doesnt dry start, other wise just make sure its not leaking and give it hell...
install it on the car and connect the drain line. use an eye dropper or something to "prime" the turbo with some oil. then install the feed line. should be good to go
