Bullseye Power Batmowheel for Ko4
#801
Matt who?
#804
I thought we figured out this psi **** a long time ago, when cardelino18 blew his motor to shreds and everyone wanted to know why.
Some had pistons gapped too close from the factory, others didn't.
I ran my k04 up to 26psi with no issues.
I knew some dude that blew a ringland on a 22psi tune.
I know others have ran 30psi for 10,000 miles.
It all depends on the tune (enrichment) and what the car can take as per timing (knock)
But WTF do I know lol.
We will see how long this motor lasts me with the s256et @ 26psi.
I have 35000 miles and if it gets me to 70000 I'll be happy.
#805
I've had the 30 spike for at least 15k miles. I get 0 KR at WOT and even light boost it only phantom knocks. (Goes to like 3 for a sec and goes right away)
Mine was tuned by brian (area47) but the base tune was matts (Mdub) tune that he dynoed 350/426 or so.
0 issues with this tune.
It lasts because I drive my car responsibly and take care of it. And btw the tune only hits 30 psi if your below 4k. The closet to 3k the higher the spike till its at 29-30.
On a 40 or 60 punch it only spikes like 26-27 and holds 25.
I've beaten a few other bolt on ss/tc with this tune and they had the same mods.
Anyway, only 2 more days to enjoy the tune..
#806
#812
Cobalt Nation
LSJ guys do turbo swaps and make less numbers so its all on how you do it lol. I love my tune no ***** given I always do crazy ****. Its all on how you drive your car as well, dont be a retard and do a pull in 5th and your **** wont go out lol.
#816
If that is what you wanted then great but I just had someone he tuned call me the day before yesterday for a retune because he does not like his (MDubs) 30 psi spike tune and its horrible drivability (light switch like power delivery). The best part about it is that all he did was load the tune no data logging to dial in the tune and no checking to make sure it is safe (30 psi safe tune LOL) with no knock. Anyone who does something like that has no business tuning cars. I would not have paid him if it was me.
#818
i've always wondered if you could make similar power/torque of the 30psi spike on less boost, i want at least 400tq in my car, i built the motor so i know it can handle the extra heat but i don't want to push it to the limit
#819
Yes. It can be done. 24psi flat produces a better overall powerband although generally makes less peak torque than a 30 psi spike but it depends because more timing and a more aggressive A/F can be run with 24 psi vs 30psi in the midrange.
#823
I can agree with this. Blew 5th gear on my way home from the dragon.
#825
Batmowheel Results
Here is the dyno runs, I did change the tune for the Batmowheel due to the tune spiking 30 PSI (didnt want to risk the motor). The Batmowheel was on a 24 PSI tune with a little more timing than the 30 PSI stock turbo tune. That is also why the torque is lower for the Batmowheel than the stock turbo run.
