Bullseye Power Batmowheel for Ko4
Old 01-13-2012, 03:32 AM
  #426
EXsoccer1921's Avatar
pretty much any turbo car is going to run higher egts than a normal car. i know i had mine glowing a few times when i was up in michigan. but never had it happen with my old m62 setup. that and its the first thing the exhaust gasses hit after coming out of combustion... its going to be hot, and its going to expand.
Old 01-13-2012, 10:15 AM
  #427
Leafydialupking's Avatar
I know this, but you dont often see turbo manifolds that use the slip fit trick on the runners.
Old 01-13-2012, 10:16 AM
  #428
SKY888's Avatar
those slips will really benefit the daily driven modified cars.........to avoid cracking of the SS manifold.
daily driven turbo cars really suffer from the frequent heat cycles encountered by the exhaust manifold.
Old 01-13-2012, 10:21 AM
  #429
SKY888's Avatar
yeah, because most of the aftermarket manifolds even some "well known companies"....don't have them......."full race manifold" wink wink
having the slip joint is nice!!!
Due to high exhaust gas pressure, many inexperienced fabricators choose to weld collectors directly to primary tubes to prevent leaks. This is not a good practice as thermal expansion will cause thermal stresses, leading to cracking tubes. I am personally using Burns double slip collectors for my compound manifold.
The double slip eliminates the need to weld the collector since it minimizes leakage around the slip joint. As the exhaust header heats up, the outer sleeve actually tightens around the collector to seal in exhaust gases, yet is compliant enough to relieve thermal stress
Old 01-13-2012, 10:24 AM
  #430
Yeah the burns double slip collector (and all burns collectors) is awesome, but not many people feel the need to spend over 400 bucks for just what you put in the picture never mind the rest of the adapters and the rest of the mani.
Old 01-13-2012, 10:27 AM
  #431
SKY888's Avatar
that's why the WERKS manifold is really cheap having all those slips...........compared to other aftermarket manifolds out there.....
for $975......it is very reasonably priced.
Old 01-13-2012, 10:43 AM
  #432
RooTBeeR's Avatar
burns are nice and expensive, no doubt
Old 01-16-2012, 01:27 PM
  #433
06RYSS's Avatar
results yet? or did i miss something...
Old 01-16-2012, 01:47 PM
  #434
RooTBeeR's Avatar
not yet, no idea if zzp has mounted it to anything yet
Old 01-16-2012, 03:54 PM
  #435
sent ryan a text. probably hear back from him tomorrow. busy guy
Old 01-16-2012, 04:03 PM
  #436
oh btw...
Old 01-16-2012, 04:05 PM
  #437
RooTBeeR's Avatar
tiny
Old 01-16-2012, 04:11 PM
  #438
RoadconeTuning's Avatar
they look like they'd cut the **** out of you...
Old 01-16-2012, 04:13 PM
  #439
batmoko4 for the 355 bmw's
Old 01-16-2012, 04:58 PM
  #440
AndrewSS/TC's Avatar
might be able to get this, sooner than expected. cant wait for results.
Old 01-17-2012, 12:39 AM
  #441
strazdice's Avatar
So what is goin on with the upgrade? Anyprogress made? Does the build need anymore turbo's?
Old 01-17-2012, 01:57 AM
  #442
just waiting to get the turbo over to zzp and mounted up
Old 01-17-2012, 02:56 AM
  #443
strazdice's Avatar
Excellent! Is the final cost goin to be the same? If we want the upgrade done we will then have to send it to zzp?
Old 01-17-2012, 03:00 AM
  #444
yes it will still be 399, i'm not sure iff zzp will be doing any installs. but bullseye will install and balance for free if you pay shipping both ways to get your turbo there and back. and the red dot is just a flaw in the site. its for "invisible mode" but it just comes up red instead of showing the 'offline' uncolored dot.
Old 01-17-2012, 03:12 AM
  #445
strazdice's Avatar
Ok thx, how does one go invisible? Has they're been any estimation on how long the install takes?
Old 01-17-2012, 06:26 PM
  #446
40rty's Avatar
Hopefully this turns out to be better than ******* and beer
Old 01-17-2012, 08:03 PM
  #447
thats not possible. nothing is better than ******* and beer
Old 01-18-2012, 12:50 AM
  #448
FasterIsBetter's Avatar
Not true, Vagina and liquor is better....
Old 01-18-2012, 02:25 AM
  #449
strazdice's Avatar
Agreed! On both! Any clue on how long the install takes beyond the obvious shipping waiting time?
Old 01-18-2012, 02:26 AM
  #450
that i'm not sure of
Quick Reply: Bullseye Power Batmowheel for Ko4
