Bullseye Power Batmowheel for Ko4
#605
Wow, Shawn. That's pretty bold. You've been here one day and going to war? I remember Dave taking care of you pretty good when you had issues with your car out at our shop. It's surprising that you would be so quick to stab him in the back on the way out the door.
I would take this information with a grain of salt. He thought they were the greatest thing out when he worked there. It's often tough to judge the accuracy of someones "information" when it changes drastically in a short period of time. There is obviously some sort of bias playing a part.
#606
I'm too JDM for you
#608
#616
Edit: Ugh ZZPs mustang dyno where their shop LNF car made 242 whp 250 wrtq stock which is pure crap. I have seen at least 10 stock LNF mustang dyno graphs an none made over 215 whp and 220 wtrq stock. The only way a LNF will make 13-15% more power than it should on a mustang dyno is by manipulation of the weight and Cd of the vehicle. That is all I need to know. I wish someone else would test this setup.
#618
It does if they mess with any of the user inputs vehicle weight, Cd, etc. What is nice about dynojets is there is no operator inputs that go into figuring HP and torque hence no operator error and consistant results. Care to actually share the results?
#619
Second- we have gone straight from our dyno to another and documented the gains. As stated before, our dyno is typically on the high side for a Mustang dyno, but lower than any Dynojet I have tested on. How much higher or lower varies from every dyno you go to. For example. Go from our dyno to Baker Engineerings Dynojet and you will only pick up a few %, maybe 3-4. Then go straight to VT Engines Dynojet and you will see another 5% or more on top of that(I think they closed shop, though). On the other hand, Livernois' Mustang dyno would typically run 3-4% lower than ours, and Motor City Steel's Mustang just slightly lower than ours. Having said that- does it really matter when you are making a dyno comparison on the same day, same dyno? How could you possibly think that is a bad thing when others are testing at 2 different dynos, months apart and you don't say anything about it. You also never mind the fact that our Mustang dyno is going to do a better job of loading the engine properly rather than just spinning a drum that doesn't act nearly the same as actually driving the car does. The bottom line is- you don't "wish someone else would test this setup." You simply want to talk **** about ZZP.
#620
What you are saying makes no sense at all. If you think we are dishonest enough to change the dyno settings in order to make one test look better than another, couldn't we just put a bad tune on the car? It's not like the dyno graph shows ignition timing. Aside from any of that, which wheel is it that you think we favored? I'm having a hard time understand where you are coming from. We have no reason to skew anything, so why would it matter?
#622
This
#625
FWIW, here is the stock dyno chart from when I first got my car. It wasn't even 242. Torque was 242, HP was only 239. I have seen them make 260 on Dynojets. Where is the issue?
