Can i see a pic of someones ZZP lower cold side charge pipe?
Hey people just wanna see a pic of someones lower zzp coldside chargepipe, preferably where the vacuum nipped and tmap sensor is.
Thanks in advance!
Thanks in advance!
Not confused, just wanna see how other peoples looks, I put mine on this weekend and took it for a drive and BOOM hot side blew off the ic lmao.
And that pic made me die laughing
Nice, I would just loosen up your t-bolt clamps, reposition the pipes so that all your ribs are behind the clamps, make sure there is no extreme angle fitment(such as the pipe looking like its going to blow through a coupler because of stress at a strong angle) and you'll be all good. The pipes all look the same when their put on correctly. Maybe someone will post a picture up for ya.
Yep i did thaat But when I got my everything zzp shorted me a clamp, and another clamp was broke in the box, so i had to reuse from stock piping, and the stock one is too small but i got it on there and it blew off yesterday and i couldnt find it .
Well you see the metal peice where the tmap and vacuum nipple are? Mine didnt come with that, it did come with a plastice peice to block off the Maf relocate. So i have my Tmap and vaccuum nipple bolted into the CP, without that metal peice inbetween.
That is a standard feature on all of our LNF lower charge pipes. If yours didn't come with it I would be surprized. Post up a pic. We will take care of it if the pc. is missing.
I will post up a,picture if you guys would like, I can have it up tomorrow, I figured the tmap and the nipple just bolt into the cp cause I didn't have that metal peice. I will post up a picture tomorrow cause I won't be home today.
And what do you mean by pc?
If you don't have the plate welded to the charge tube, how did you bolt down the sensor? The bolt hole is tapped in the plate. Are you just looking at where the coating ends in the picture and thinking it is a separate plate?
The plate is welded ther, with the holes for the tmap and nipple, what I don't have is that silver plate shown in the picture above, and I was wondering if I needed that. So the tmap and nipple I have bolted into the charge pipe, just without that silver plate in the picture.
And there is the maf relocate there also, which I bolted the plastic block off there cause I am not using it.
Get what I mean? Lol
