Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   Car wont start/crank/turn (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/car-wont-start-crank-turn-319148/)
Gugi96 Sep 14, 2015 07:03 PM
The battery and starter were both tested and both work properly, i bought a new fusebox and that didnt fix it. The only way i can start my car is by putting it in neutral and putting the key in the on position and taking a small wire and putting it in two holes where the CRNK fuse box is. This happened after installing aftermarket clutch
714ionredline Sep 15, 2015 12:24 AM
Have you checked if you maybe disconnected or have a bad clutch switch on the clutch pedal?
