Catch can project
I decided to get an air oil separator since I get a small amount of blowby. Never seen the inside of the MPx, and I don't like any of the crappy generic ones that have poor/no media, bad filtering, bad design, etc.
I boiled my choices down to Conceptual Polymer's a/o separator or Moroso's. Moroso's is more like a catch can than a separator, but they call it a separator. Anyways, I decided on the Moroso, since it was shorter, and it came with a bracket. Disassembled, you can see that it has a divided wall between inlet and outlet, and a nice stainless net rolled up as the media. This stuff won't break off like steel wool would. To be safe though, I ran a lot of very hot water through both sides. https://farm8.staticflickr.com/7263/...d036b085_b.jpg Here it is assembled. The drain valve adds a significant amount of height. I may reduce that by using a different setup. https://farm6.staticflickr.com/5336/...39a1fd0c_b.jpg So it's probably hard to see what's going on with the next picture, but basically, I took a right angle aluminum stock, and cut it to about 7.5" and drilled holes to fit the bracket that came with the catch can, and the 2 bolts that stick up. Finally, I had to rotate my K&N a little bit. I normally keep the metal part facing straight down, but I had to adjust it so that I would have room for the catch can. https://farm9.staticflickr.com/8023/...21069b86_b.jpg https://farm9.staticflickr.com/8017/...06206a2a_b.jpg More pics when I have it hooked up later this week. I'll have to tackle that damn valve cover line. Leaning towards cutting with a dremel. |
Evidence that it works. This is a one off clear plastic version that Moroso made for documentation:
http://www.youtube.com/watch?v=Y9klkDCItEY |
Very cool. Thanks for sharing. Please keep us updated.
Damn they were getting it lol
nice man, where did u get the net and the can??
The stainless net comes with the can. There are 2, one for each side of the divider. You can get these from Amazon or a number of places. They have different versions with special brackets for cars. I got the universal one.
can u link me to that one
So, something else to note, especially for the K&N intake users. I suspect the hose running from the valve cover to the intake is NOT angled enough into the air stream to keep the check valve from opening. The result is that oil vapors are getting pulled into the intake from the valve cover. This should not be the case if the hose fitting is angled into the air stream properly.
I'm not sure if the barb extends in past the metal intake. If it does, I may cut it at an angle so that it can catch more air. This connection should NOT require a catch can, due to the built in check valve. |
Originally Posted by Wangspeed
(Post 6550756)
I may try it myself, so I can finally install this MPx I've had for a while now. |
Originally Posted by Stamina
(Post 6552983)
Word on the street is that you can cut zip ties and wedge them underneath each of the barbs that hold that dang valve cover line connection on. A few people have seemed to have success doing it.
Did you ever look at the one by Elite Engineering, by any chance? They market it for Vettes, but a separator is a separator. The only difference is the bracket.
Corvette PCV Oil Catch Can |
(Post 6553021)
I have a hard time believing that method will work to disengage all 4 clips. Maybe some of them, but not all.
Originally Posted by Sox-Fan
(Post 6553029)
I cut mine with a dremel.
Very interested in this, just put on my k&n on Sunday and noticed the oil at the turbo inlet and was a bit worried. How is the fitment with the valve on the bottom?
Until something better comes along.
https://farm8.staticflickr.com/7265/...36412a1a_b.jpg https://farm8.staticflickr.com/7266/...46bfbb23_b.jpg |
1 Attachment(s)
(Post 6553021)
Did you notice any ill effects from rotating your K&N filter, fuel trim wise? Many ppl swear it makes a difference. Attachment 60511 |
Doesn't matter to me. I'll just adjust my fuel trims if they are off.
Blah I still need to get one
Originally Posted by Miko
(Post 6560284)
Worked for me! Use as thick a tie wrap as you can wedge in there. the trick is figuring out first where the tabs are oriented. I don't know how I would have gotten the line off the turbo connection otherwise.
http://i1098.photobucket.com/albums/...sworkgreat.jpg I did actually try the zip ties for all of 2 minutes before throwing them away. Added bonus, it will be MUCH easier now to replace my valve cover with a powder coated one :) |
This is from a single track day. I emptied it after each session. I'm going to pull my valve cover off soon to see if I have a broken lash adjuster, which is causing additional issues.
20 ounce drink bottle. https://farm9.staticflickr.com/8426/...68b94897_b.jpg |
:wtf:
Wangspeed, what intake are you using?
That's a K+N CAI in the picture.
1 Attachment(s)
There is an OCC that ddmworks offers for the LNF kappa. It has a bracket for a 10mm you can fix somewhere in your engine bay. Well made
Oil Catch Can Attachment 59835 |
| All times are GMT -4. The time now is 10:00 AM. |
