Clutch master main line
Has anybody experienced the OEM Master cylinder line popping off? I had it pop off on me in a parking lot reconnected it and made sure it was snug and tight. Bled the system and it held on for about 2 days and popped again. I'm going to replace the line itself but was just wondering if other guys had the same issue.
Popped off of what? The connection block on top of the transmission?
I'll assume so, as I'm not sure what else would "pop" off.
That connection requires a pin clip to hold it in place. Most of the clutch hydraulic system uses this system, as well, so I'd bet that where ever it is that you're trying to reattach a hose... you're missing the clip.
Pretty sure this is what you'll be looking for: https://zzperformance.com/products/clutch-clip
Like this:
Final configuration will look like the parts with the blue paint on them:
Like this:
I've never had that happen. Honestly never removed it from that point either.
I'd guess that whatever it is that holds it there (likely something stupid like a plastic clip) is broken. Probably need a new line.
$35 - Hose, LNF Clutch Actuator Cyl 5-Spd Man/Trans (MU3) 24252285
Jrflint09
Apr 7, 2019 08:13 PM
