Dyno'd Saturday
Clutch would have slipped less if he used 3rd but no big deal. Also 4th will show more torque but less hp vs 3rd. There is no true 1:1 ratio on the F-35 trans which is annoying come dyno time. I also richened PE lambda from 0.88 to 0.86 which will take it to 12.7 a/f. Boost is 287 kpa max which at that altitude is 30 psig but the pressure the engine sees is the same as 25 psi at sea level so it is safe for the pistons.
Good numbers! Atleast you can dyno your car -- I'm scared to go with my E85 tune because the clutch slipped just a little on my 93 octane tune. WOT runs in 4th and 5th gear starting below 4000rpm on the streets are a no go for me and result in instant clutch slip to redline. I did that once and never again.
However any other gear holds up to the abuse. I even NLS 2-3 and 3-4 without any slip. Broke an axle at the track last fall launching on drag radials. 60,000 miles, stock clutch, tuned since 41,000 miles. I say stock on the stock clutch as long as you can to prolong the life of the transmission.
Cobalt SS/TC (Leemanfor) - YouTube
Heres the Youtube video. Ignore the crappy ass camera quality haha. You can hear the Forge VTA BOV really well here
