E85 Filter???
Hey everyone. I was looking you see if anyone has any suggestions on what fuel filter I should use for E85. I currently have stock filter but I believe a 1500 micron filter is needed due to the stock one will clog up. Any suggestions on what you're using and where I can get one from. Any help kids appreciated.
Stock is all you need
I don't think the LNF fuel filter is serviceable. Anyways e85 isn't going to clog a fuel filter unless you're running some backyard home brew e85
It's serviceable and I'm not using homemade fuel. I'm using pump E85 but I was told that the filter need to be swapped out or it will clog it up.
Plenty of people have ran e85 without changing the filter on their LNF
Do you plan on pulling your in tank fuel pump?
Depends on miles on the car and how dirty your tank was before you switched to e85. Changing the filter is just good peace of mind.
(Post 7664835)
Still not THAT hard to do if hes worried about it, unless its not replaceable.
