F35 question
Does anyone know the specs of the fill and drain plug in the F35 transmission?
The banjo fittings I got for my trans cooler turn out to be the wrong size... Thanks! |
Buy GM 55561146 Plug, genuine OEM part
Buy GM 55568847 Plug, genuine OEM part It looks like both are M18x1.5, at least according to what I could find. |
Thank you Tdubbs, that makes sense. I got M14 x 1.5 as the specs and it was too small.
Just ordered the M18 :D |
why do you have a trans cooler for the f35? there is no pump to circulate the fluid
(Post 7685811)
Tom- I think he is putting one in.
Originally Posted by ECaulk
(Post 7685815)
This. Its specifically because he road races his car, trying to make the gear set last longer.
(Post 7685827)
quaife
(Post 7685804)
(Post 7685811)
It was recommended by Powell and I figure it's a fairly uninvolved way to give the trans some extra protection. https://cimg8.ibsrv.net/gimg/www.cob...557df9e074.jpg |
adding a trans cooling system to a car that sees regular road racing is a great way to keep the transmission happy. heat reduces the viscosity and lubricity, and you can end up will galling on the teeth. people would be amazed at how hot a manual transmission can get when road racing.
Just for reference in case anyone else has the same question, M18 x 1.5 was the correct size!
Wow, I forgot about this LOL, glad it worked out in the end
