Future mod questions
Old Jun 22, 2012 | 09:20 PM
Fastgti69's Avatar
I'm going to be going Big turbo very soon and had a question. I currently do not have a clutch and wanted to install the clutch and turbo kit at the same time. In doing so, I have to break in the clutch. In that time while breaking in the clutch for 500+ miles or so. How should I get tuned for it is what I'm asking basically.
Should I break the clutch in etc on stock k04 tune. (not going WOT at all just cruising like a bitch lol) Or should I install the clutch, break it in. then put the turbo kit and just tune it then and there. I know I'd obviously be saving some money just doing the turbo and clutch at once. Just some advice or anything would be awesome.
Old Jun 22, 2012 | 09:23 PM
09BlueBaltSS's Avatar
You will be ok doing both at the same time. Your not supposed to be putting power to the new clutch anyway but rather a ton of engaging/disengaging to get the clutch/flywheel bedded to each other
Old Jun 23, 2012 | 12:32 AM
Fastgti69's Avatar
I know I wont be able to put the power down right when it's installed. I obviously wouldnt be able to fine tune because I need to break the clutch in right? I would be okay with current tune until I break in the clutch? Then I will be fine tuning and going WOT etc.
Old Jun 23, 2012 | 01:52 PM
SSlobalt's Avatar
You can use the KO4 tune for a bigger turbo, if you're just breaking in a clutch. It will run fine. The MAP sensor will pick up on the increase in airflow and adjustments will be made.
Old Jun 23, 2012 | 07:24 PM
Fastgti69's Avatar
Thanks for the advice bro.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
