Getting a p2187code
Getting a p2187code
Need some input from the lnf experts. It's a lean code but my car smells like its running rich. Car is a hhr ss auto with Hahn catless dp and a drop in kn filter. I cleaned the maf that didn't fix it.
When my car was throwing a p2187 code it was running pig rich and ended up being a vacuum leak at the pcv line on the valve cover. Could possibly be a faulty evap purge solenoid.
If it's leaking at the o2 housing flange then yes. It would allow air to enter the system at the upstream o2, it would then see a false lean condition and try to correct it with more fuel, causing you to be running too rich. That's a simple explanation.
