GMPP clutch not for LNF?
Old 01-14-2019, 10:32 AM
cw383's Avatar
I was looking up a part number for a GMPP clutch to help someone here. I ran one for 2 years with up to 432HP with no problems, but with my new setup, presumably near 500hp it met its match. I found the part number, and it now says "(*Do not use this kit for LNF vehicles) ". I dont remember it ever specifically saying not to use it on LNF's. Any idea what thats about?
Ecotec LSJ Clutch Upgrade Kit 19212712
Old 01-14-2019, 03:46 PM
armcclure's Avatar
afaik GM just can't recommend it because it came out before the LNF. It fits and functions perfectly fine.
Old 01-14-2019, 08:43 PM
63 Nova SS's Avatar
It's had that warning for quite awhile. Mine had it when I got it 2 years ago and has been a great clutch so far.
Old 01-15-2019, 06:35 AM
I thought you had one for longer than that.
iirc Tom said it was due to the fact GM would void the warranty if it was used on the LNF, at least the part warranty, not sure if it was voiding the power-train warranty (although that doesn't apply anymore).
Old 01-15-2019, 07:14 AM
cw383's Avatar
Wasn't it CED that actually showed using a chopped up Bic pen to align the dowels on an LNF flywheel?
Old 01-15-2019, 08:30 AM
It's possible they posted it up, but from a CYA standpoint they had it on their sales page for a long time.
Old 01-16-2019, 09:22 AM
armcclure's Avatar
You have to do the same thing on the LSJ; 6mm pins in 8mm holes. In reality though if you work the pressure plate bolts down like you're tightening a wheel it centers itself up.
Old 01-18-2019, 12:09 AM
ThePanduuh's Avatar
The guide was designed for LSJ users as uses stock LNF pressure plate which uses the bigger pin holes. I am 100% sure not many have used or even seen the stock LNF flywheel in the past 2 years as it's gone up in price so much no one buys it. I found a good deal on one and snagged it. My OEM LNF clutch kit fit snugly without needing the BIC pen.
That being said the GMPP clutch kit with ZZP flywheel (and new hardware for flywheel at minimum) is the most solid <$600 clutch kit out there. Properly ramped tune will help make it last longer.
Old 01-19-2019, 08:32 PM
CobaltPartsStore's Avatar
Yup, you are all correct.
The GMPP clutch was designed for the LSJ originally. Customers have been using them on the LNF as well.
The warranty issue was the reason I suggested it only be used for the LSJ.
Old 01-19-2019, 08:38 PM
ThePanduuh's Avatar
and warranty is only good if installed by GM and NOBODY is paying GM in this day and age to install a clutch. So warranty is already void already. I should have gone GMPP when I did my clutch.
PS are Powell CABs pre pressed into LNF arms still available through you? Need to tell people where to go!
Old 01-19-2019, 09:34 PM
I am not set up to do them just yet, I am hoping to a month or so down the road though.
Old 01-20-2019, 02:52 PM
06cobaltss/ss's Avatar
hopefully my 2nd one last longer then the current one haha.
Old 01-24-2019, 05:40 PM
r1owner's Avatar
Sorry, I just want to make sure, so the kit works in the LNF, with the LNF flywheel or a ZZP flywheel for an LNF?
Old 01-24-2019, 05:45 PM
ThePanduuh's Avatar
either one. The OEM lnf flywheel is $600ish last time I checked. If you get the ZZP flywheel it has smaller dowel pins so when torquing the pressure plate down, you’ll need to put the BIC pen shell to help center the pressure plate on the dowel pins. Should be able to find pictures online. But I think explaining makes sense?
link to pictures on CED old site. Order from zzp or oempartsdepot.com
Images of Ecotec LSJ Clutch Upgrade Kit 19212712
r1owner (01-24-2019)
cjdz24_Z28
08-04-2017 04:40 PM
Dart_SI
06-19-2017 12:08 PM
Sinnerx
06-13-2017 10:31 AM
TroyK
08-08-2016 03:21 AM
duffman11
03-23-2013 01:22 PM
Quick Reply: GMPP clutch not for LNF?
