Going even bigger on the turbo. Share your thoughts
In the pursuit of 600+whp this summer im looking at a larger turbo (i love you s256et, but its time we part ways).
S362 vs HTA3582 Discuss! :cool: |
S259?
zfr???
Originally Posted by mexi_loco
(Post 6849885)
zfr???
Originally Posted by kdub1492
(Post 6849886)
ZFR isin't bigger lol
(Post 6849886)
I'll take your 256et.
Originally Posted by ULWizSS
(Post 6849895)
Maybe not the smaller models. The BorgWarner EFR 7670 Turbo can support his goals and would be my own choice.
An EFR turbo would get him there like you said the 7670...the only problem I see in going with a big Efr or a s3 series is fitment |
Didn't zzp take a s362 compressor and put it on a s259 turbine and center. Little better spool with the same top end
They just put a 200 series cover on it. The 300 series race cover is to big to fit behind the motor. How about a 6262?
(Post 6849955)
That is sad that the 362 is too big, i just remember that one got matched up before. I did not know it was put into a 200 series :( |
HTA would spool way better anyways, and be very unique in the cobalt world
Originally Posted by ford
(Post 6849862)
S362 vs HTA3582 Discuss! :cool: For Sale: Forced Performance HTA3586r |
If you want to bring the car back down we can set you up with a custom manifold and turbo that will reach that easily. Your issue your going to have is the motor at that point. On ryans car we had to back off the power because the block wasnt girdled. 30psi tore up the head gasket with ARP head studs installed. Give me a call when you get a chance and il fill you in on some of the stuff we have been working on down here ;)
Originally Posted by silverbullet08
(Post 6850058)
With the fact a 300 series turbo isn't even gonna whistle until near 6000 rpm, I would go the HTA route. If you really wanna have a sweet setup, look into the larger EFR turbo that has already been mentioned. Would be interesting to see if it fit behind the firewall.
You could get Treadstones manifold and do a 35r series turbo also. That should do 600 HP on E85 easily. |
S262...done...
Originally Posted by raver0789
(Post 6850183)
S262...done...
And you won't lol. You will need to contact ZZP and they can get you hooked up. But a 259 will do just fine. It will make over 600.
yeah i had the 262 on my car. thats what i made the 591 on before running out of fuel. its basically a 362 with a 7" cover instead of the 8". but the spool on the .70 housing sucks.
(Post 6850058)
(Post 6850216)
My headgasket never even leaked and looked good when I took it out. The motor lasted for quite some time without the girdled block at 30 psi. It was the times I tried to go to 32-33 that broke it. As long as the piston clearance is good to take the heat it should last a good while. 30 would be my max on a stock block.
What internals did you buy so far? Are you building only the bottom end or the ehole long block?
Originally Posted by AyrtonSenna
(Post 6850366)
if you're building the engine. you don't need a crazy huge turbo. get a turbo like the 259 that will make the 600 you're looking for. but have a killer powerband to go with it.
