hahn super 20g turbo?
Old Sep 8, 2013 | 11:56 AM
  #251
Wert842's Avatar
^ so that should put you around 390-400ish.
Old Sep 8, 2013 | 12:17 PM
  #252
N1ckateen's Avatar
according to the dyno 336 lol. hot air intake ftw! got my zzp 3.5" "big turbo" intake in yesterday. gotta get a bigger 90* coupler though. the coupler it came with is a 3" to 3.5" 90* elbow coupler. need a 4" to 3.5" 90* coupler so it will fit onto the turbo. put that on then the gms1 sensors on. get a bit more timing and maybe 2 or 3 psi more from james with a bit more boost ramp. next month get 3 paychecks plus quarterly bonus so gonna get clutch. contemplating going ahead and buying the new injectors and upgraded fuel cam just to get those goodies started. then hopefully just need pistons. valve springs. and fuel pump. then corn juice ftw.
Old Sep 8, 2013 | 12:33 PM
  #253
Wert842's Avatar
I still have no idea how you dyno'd so low. I would've been pissed.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Sep 8, 2013 | 12:59 PM
  #254
N1ckateen's Avatar
hot air. poor fans. hot ambient temps. I know the dyno isn't bad because when I was on stock turbo it was ~40* out and I put down 317/359 which are very expectable numbers on a fully bolted k04. plus I dynod my gms2 lsj there and put down 246 then full bolt ons with e85 lsj I put down 287whp. so it seems pretty spot on when it comes to numbers. and I've seen probably 20 other cobalts dyno on this dyno with pretty spot on numbers as well. aside from one other buddy here that made 288 on his lnf with same mods as I had on the k04 and almost identical tunes. but he had an ebay ic and he said his iats were well into the hundreds. which was my case with my air filter being directly on the intake and it being 80*+ out during the pulls. every pull I lost on average 7 horsepower. going from 336 to 329 to 322 then I did a 4th pull and hit 315whp. so IMO heat was definitely the factor. that's why i'm hoping this 3.5" short ram from zzp will help keep the air a bit cooler going into the intercooler so it has to do less work.
Old Sep 8, 2013 | 01:07 PM
  #255
N1ckateen's Avatar
i'll upload my dyno graphs in a sec
Old Sep 8, 2013 | 01:09 PM
  #256
N1ckateen's Avatar
Uploaded with ImageShack.com
Old Sep 8, 2013 | 01:14 PM
  #257
N1ckateen's Avatar
idk what was up with the tq. he couldn't get it to read and it was 10pm so he was in a rush. all in all was a waste of 80 bucks and an entire evening.
Old Sep 8, 2013 | 02:08 PM
  #258
Wert842's Avatar
Ya those torque numbers are retarded low. There has to be something wrong somewhere. Do you have an upgraded intercooler?
Old Sep 8, 2013 | 02:10 PM
  #259
N1ckateen's Avatar
Mpx intercooler
Old Sep 8, 2013 | 02:23 PM
  #260
kdub1492's Avatar
What size inlet do you have on your turbo? What's the need for the 3.5-4" coupler?
Old Sep 8, 2013 | 02:27 PM
  #261
Fastgti69's Avatar
He has a 4" inlet.
Old Sep 8, 2013 | 02:42 PM
  #262
kdub1492's Avatar
Oh okay, have fun tuning for the intake, it's a PITA. Too much air thru the MAF, we are trying a air straightener in mine to slow it down a bit as dispense the air more evenly
Old Sep 8, 2013 | 02:52 PM
  #263
N1ckateen's Avatar
I have maf relocate and am running a blowoff valve.
Old Sep 8, 2013 | 02:55 PM
  #264
Fastgti69's Avatar
Yep, we got MAF relocate lol.
Old Sep 8, 2013 | 02:59 PM
  #265
N1ckateen's Avatar
havin any luck with urs payam?
Old Sep 8, 2013 | 03:02 PM
  #266
kdub1492's Avatar
We are dialing it in now, if it is still acting weird I will just do MAF relocate. I already have the pipe for it, I just have the block off plate in right now haha
Old Sep 8, 2013 | 03:08 PM
  #267
09CobaltSS1's Avatar
Originally Posted by AARON-SS-TC
NOW this should be the real word on it, so what do ya say on the s20g 09cobaltSS1???
Originally Posted by Shortbus
Waiting on this review LOL
There isn't really a whole lot to review, it's just an opinion.. lol
I knew the 20g has good power potential, especially from my dealings with the dsm world, but I was just never a real big fan of it. Long and short of it, for the money, I would say it's probably one of the best if not the best bang for your buck turbo available. I came into tuning this particular car (LNF HHR) with sort of sour taste for the 20g, and came out of it with a new respect for it. Is it "old tech"? Sure. Does it spool a little later? Sure. Is it ridiculous? Not at all. I actually ramp the boost in my efr (and all the zfr strapped lnf's I have tuned) to basically the exact same rpm as where a 20g would hit full boost anyways (4200rpm), so it's really not a big deal. Everyone gets so hung up on wanting full spool by 3,000rpm, but they never really consider the consequences of such a fast spool particularly when matched with a larger than stock turbo. Plus, who the hell is racing at anything below 4000rpms anyways?
Old Sep 8, 2013 | 03:20 PM
  #268
Shortbus's Avatar
I was thinking the same thing the other day, with ramping needed on the zfr it would be the same as the slower spool on the 20g.
Old Sep 8, 2013 | 03:21 PM
  #269
Fastgti69's Avatar
I'm finally boosting 24 psi. Problem was boost solenoid I'm guessing. I'm still getting Compressor surge, or WG flutter I'm hoping. I got a 1.5 bar spring and I need to change it out. I've been lazy the past 2 days cause of my Bday. I'm still recovering LOL.
Brooo this video comes to mind when you have a part and you're not using it lol.
I agree with this 1000% I had a boost ramp with my ZFR for 4500 rpm I think, and it was still amazing. You have to remember when you're spooling you're still making power, just not full power. I would never want to have full boost at 3k rpm with a turbo than can produce enough torque to blow the tranny. **** that...
Old Sep 8, 2013 | 03:36 PM
  #270
kdub1492's Avatar
MAF relocate isn't always the best solution. Best to keep the MAF as close to stock position as possible IMO. With this intake the MAF may be taking in too much air so it may force me to use the relocate
Old Sep 8, 2013 | 03:38 PM
  #271
N1ckateen's Avatar
I have a little flutter sound at 4500 when I hit full spool but after that it's just smooth loud air/turbo whistling sound.
Old Sep 8, 2013 | 03:43 PM
  #272
Fastgti69's Avatar
I agree with you, but only when it's a stock turbo. Or something that is stock like, EFR or k04. I'd never run that on a turbo size like ours.
Mine is flutter at 4.5 but stays till 5.5. then after that it's smooth. idk weird ****.
Old Sep 8, 2013 | 03:54 PM
  #273
AARON-SS-TC's Avatar
nice review, and good comments. I think Hahn will be happy for them too, because we have a real tuner do a review on it without scewed issues...lol
I personally like the revised BNR, but the price of the Hahn s20g is awesome, especially when its on sale for 20% of the $1199 price = $960.00!!!
I hear an mbc is best to use with those turbos though to keep it from flutter and keep it consistant..
Old Sep 8, 2013 | 03:57 PM
  #274
Fastgti69's Avatar
Get the 20g bro, it's badass. Great pricing too right now. MBC is a must, I'm an idiot for not using one back then. I want an electric one now, make that **** fancy haha.
BTW, cool thing about 20g or BNR is that you can do surgery with them. You can change the wheels to a bigger turbo on both. Either a 25g like mine or a BNR 60-1 turbo.
Old Sep 8, 2013 | 03:59 PM
  #275
yeah man...lol
