has anyone sent their oil for oil analysis?
I gues on the camaro forums they are saying the direct injection motors(3.6 V6) are very hard on the oil and it should be chaged often.
Has anyone sent out there LNF oil out for oil analysis to see if we should be changing our oil more frequently or not. On the Camaro forums they are saying it is must to change it every 3,000 miles but they are not using synthetic oil either (but some form of dexos.) |
never....heard of that one..
haven't done anything with oil. but i just sent some gas samples out for testing to see what octane the 91 here really is.
how is direct injecton hard on the oil? di motor oils the same as port injection, just get the gas in combustion chamber instead of mixing it with air in the head. i dont get it
Originally Posted by tomj77
(Post 6309986)
(Post 6309986)
People here have performed UOA. Search, but it's better to go to bobistheoilguy for UOA. Also, if you're going to do this, install a Fumoto oil drain valve. Will make changes and UOA easier.
Originally Posted by Wangspeed
(Post 6313535)
Originally Posted by bri2203
(Post 6313594)
I justed used one of those for the first time on a 2010 Duramax, it was nice not having to get out a wrench.
http://farm6.staticflickr.com/5252/5...18061c8e_z.jpg Perfect for UOA, or if you overfill, plus it's just cleaner when doing oil changes. |
I looked into buying one of those.
How long is the drain time? I would think longer because of the smaller hole it has to drain through. I usually let mine drip for a while until there is nothing left. |
Originally Posted by iLikeBoost
(Post 6310034)
Because Camaro
Originally Posted by Gremlin85
(Post 6313746)
how much do those things cost?
(Post 6313733)
I put one on 4 of my vehicles since I found out about them. Good position on the Cobalt too.
