High Pressure Fuel Pump Tick- GM bulletin but does not include 2010 models
Recently I noticed a tick that I never heard before.
I could not hear it when it is in open loop but once has been running for a few minutes the idle drops and you could hear a loud tick every 1-1.5 seconds. I used a mechanic's stethoscope to confirm it was the high pressure fuel pump. I took it to the dealer, and they said the tick is normal due to GM Bulletin #06-06-93-001G, which included 2008-2009 Cobalt SS/HHR SS. A few days later I compared the tick with a 08 HHR SS with 30,000 more miles and the tick was less apparent. Also the bulletin does not include 2010 models, Was the fuel pump changed in 2010? Any guess why my tick is quieter than other models with more miles? |
the "Tick" is normal... lol
Normal. You're just paranoid. When I first looked at Cobalts I thought there was something wrong with the ones I was looking at.
If it bothers you to much, just go to crate engine depot site and order the rubber cover they have to dampen the sound.
My tick sounds like a kitty cat purring lol
there is a recall on the fuel pumps. it was finalized on the 12th of this month, so just call gm and change it out for piece of mind.
Originally Posted by AARON-SS-TC
(Post 6801123)
What was wrong with the fuel pumps and what is the new part#?
i think he's talking about this:
https://www.cobaltss.net/forums/reca...l-pump-287209/ I deal with GM Alot and haven't heard anything about the HPFP having a recall. |
i freaked out the first time i herd my car do the same thing i posted vids and read up on it every one sead it was normal and a few ppl even sent me vids of there cars doing the same thing
there cars had about 15k and 35k my car has 73K |
Originally Posted by imperialsedanSS
(Post 6801242)
there cars had about 15k and 35k my car has 73K :lol: i think we all did at point or another |
Direct Injection engine. The fuel pump makes a characteristic tick. Yippee Skippee. Can we move on now?
The HHR you listened to may have had the HPFP noise cover in place.
I can't remember if mine came with one or if it was a service visit installed item, but at some point I ended up with a noise cover over my HPFP. I later took it off so I could get to stuff easier. |
Just another LNF worrying it's owner with it poor way of delivering fuel.
Originally Posted by bratboy90
(Post 6801361)
Originally Posted by Team SS
(Post 6801155)
(Post 6802710)
yes, thats what I was talking about....thanks:)
lol yea. thats mainly the base models |
some have a thicker cover on the hpfp and some just have a flimsy piece of fabric, there is a constant tickign which is the hpfp and another higher pictched tick which is the vvt ive heard.
Since they don't have return ports on their fuel canisters, that recall could not apply to LNFs.
All this time, I thought I had bought a diesel.
Damn. |
Originally Posted by bri2203
(Post 6800922)
Rubber cover for fuel pump sound dampen
Originally Posted by 40rty
(Post 6801001)
Thread from the dead :lol: but the rubber cover he is talking about is actually a molded foam piece that goes over the pump. Lemme look up the gm part number real quick.
Edit: the part number is 12628069, you will remove the metal shield around the hpfp and this foam section is molded to fit on one way around the pump and lines. Then you put the metal shield back on. Gm calls it a insulator so when you look it up it may say insulator or silencer or cover depending where you buy it from. This is about what it looks like https://www.skyroadster.com/forums/a...ulation_02.jpg http://www.crateenginedepot.com/Asse...8069_large.jpg May look slightly different now, they use basically the same one on everything with the di ecotec after 2010. |
(Post 6801001)
Originally Posted by Kolt
(Post 7702591)
Edit: the part number is 12628069, you will remove the metal shield around the hpfp and this foam section is molded to fit on one way around the pump and lines. Then you put the metal shield back on. Gm calls it a insulator so when you look it up it may say insulator or silencer or cover depending where you buy it from. This is about what it looks like https://www.skyroadster.com/forums/a...ulation_02.jpg http://www.crateenginedepot.com/Asse...8069_large.jpg May look slightly different now, they use basically the same one on everything with the di ecotec after 2010. EDIT: the two pumps are very different I will explore other options and possibly make my own. |
Fuel pump part number for a lnf? There wasn't a bulletin for replacing the pump specifically for noise. What does a lf4 go into.
