Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   How to change LNF Transmission Fluid? (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/how-change-lnf-transmission-fluid-274044/)
ApizzCobaltTurbo Mar 13, 2012 12:30 AM
I have an 08 cobalt turbo. Its got 43,000 miles on it now and I was planning on changing the transmission fluid soon. Also what transmission fluid would you reccomend? Anyone who has done this or any step by step how to's with pictures?
Turbalted Mar 13, 2012 01:11 AM
Should just be two plugs on the side of the tranny. An upper one(for filling) and a lower one (for draining)
Also here is a link you should look at before getting any fluid
https://www.cobaltss.net/forums/driv...thread-230048/
gotboost?17 Mar 13, 2012 06:04 AM
subd
michiganfootball911 Mar 13, 2012 08:04 AM
i plan on doing this same thing this weekend. I bought 2 quarts of this.
Red Line - Redline MT-90 Manual Trans Fluid #RDL-50304
Only use gm fluid or the corrent redline mtf. no other fluid should be used in the lnf
jmfselu Mar 13, 2012 08:22 AM
yah get the gl-40 GM oil. i did mine at 60k miles and it felt so nice.
DerekDTP! Mar 13, 2012 09:33 AM
Subd
tomj77 Mar 13, 2012 09:51 AM
Why u guys changing ur tranny fluid? U shouldn't ever have to change it, but if u want to why after only that many Kms? Manual trans there is no need to change it otherwise they would make a easy to access filler port.
ApizzCobaltTurbo Mar 13, 2012 03:14 PM
Thanks for the posts. I just feel the transmission fluid has been in there for 4 years going on 5 and if I was a transmission I would want fresh fluid. Specially in a performance car such as the Cobalt SS Turbo!
tomj77 Mar 13, 2012 08:25 PM
lol well i guess if it wants freash fluid who am i to argue
Turbalted Mar 14, 2012 01:37 AM
Took a pic today for ya. Its really the only one i could get, and it was just cause i was doing an oil change and remembered to do this lol
http://i1135.photobucket.com/albums/.../Lnftranny.jpg
This is on the drivers side of the tranny. The red arrow is the drain plug, and the green arrow is the filler plug.
ApizzCobaltTurbo Mar 14, 2012 02:21 AM
Very helpful picture. So I hear people buying 2 quarts of the transmission fluid (OEM part # 88862472) but it only takes about 1.7 quarts. I feel however how much fluid comes out of the transmission, I would put that same amount back in. I also see other posts of people saying to take the drain plug out, let all the fluid drain out, then fill it till it starts leaking out of the drain plug. I thought you would have to fill it past the drain plug or how would it drain in the first place....?
DiabeticKripple Mar 14, 2012 02:23 AM
you fill until it comes out the filler hole, not the drain hole haha.
ApizzCobaltTurbo Mar 16, 2012 02:32 PM
Oh got ya! Would it make a difference if the car is on jack stands and not a lift?
DiabeticKripple Mar 16, 2012 02:47 PM
Nope
Frogstofall Mar 16, 2012 02:48 PM
Very very slightly probably but not much.
I'd like to know what size Allen Key the plugs are. Anyone know?
gray ss/tc Jun 13, 2012 07:11 PM
Subd
chris88z24 Jun 13, 2012 07:16 PM
The service manual says to also coat the threads of the plugs with high temp thread sealant. Tighten to 37 ft-lbs. I'm changing mine this week because the retarded dealership used the wrong oil in mine and it shifts like shit.
chris88z24 Jun 14, 2012 12:30 AM
Just changed mine. It is easier than changing the engine oil on an SS/SC because of where the oil filter is, haha.
gotboost?17 Jun 14, 2012 07:24 PM
great info/pic, thanks
Geo_SS Jun 17, 2012 05:05 AM
sub'd for later
good info to know
C_A_D88 Jun 17, 2012 10:03 AM
In for later
06SilverG85 Jul 2, 2012 11:08 PM
What have you guys been using to put in the new fluid? I am planning on doing this soon and the fill port is in such a tight area.
SSlobalt Jul 2, 2012 11:16 PM
I use a pump that is made to pump oil into a boat lower unit.
Frogstofall Jul 3, 2012 12:21 AM
I use one of those cheap $2 funnels and a 3' section of clear hose (I wanna say its 3/8" ID). Can obtain both at Menards or any worth while hardware store.
exninja Jan 16, 2014 06:34 PM
Does the service manual say anything about having the trans temp at normal operating temperature? I've heard of lots of "fill-for-life" auto trans' requiring that, such as the auto Cobalt.
