How much psi a forged LNF/LDK can hold ?
I have rebuilt my LDK, Molnar rods and Wiseco pistons.
How much boost can hold this config ?
I'm now on 25 PSI on my K04+
Thanks for the advice
Marc
Marc
All of the psi
But honestly above 27 won't do you any good. I have a + also and it spikes to 27 and fades from there. A bigger turbo you could go 28-30.
I was running 28 psi on stock lnf for 2 years on 6758 before turbo went and I bought a built engine. now I run 30 psi on s257. well 30.5ish. so ya, 25 on a built bottom end is no problem. as long as ur not doing it on like stock k04 or something, which is not meant to run over 23ish, cause it just blows hot air and more likely to knock and do damage. I wouldn't run any more on the turbo u have
