Humidity affecting performance?
Does anyone else notice an obvious drop in performance in humid weather? At the same temperature, I feel the car is definatly slower when humidity is close to 100%. Again at the same outside temp, the cars is faster when the air is dry.
Is it a normal phenomenon? If so, what is the underlying reason this happens? PS I'm trifecta tuned if it changes anything Thanks Louis |
Coming from the NHRA drag racing scene... I can confirm that high humidity affects performance in a negative way. Cool and dry air always made the most power. Hot and humid (and high altitude)= slow.
I believe it has to do with the added water vapor in the air.... it lowers the amount of oxygen being burned in the engine (water taking up space instead of O2)... same goes for hot air... its less dense than cool air so less O2 |
You see it so much more with a MBC. My boost levels change daily based on the weather. Lol. In hot humid weather my boost will drop a few psi and it feels SO much slower. On cold days its the opposite.
yes it does affect performance, as the AIR is not as dense, so your engine is not picking up as much air as it should be
(Post 7145539)
Moreover, air saturated in water is in fact less dense than dry air (contrary to popular belief) because evaporated water wheighs less than the oxygen/nitrogen it replaces. To sum it up: at a given temperature, a higher humidity index will always make your LNF produce LESS power. End thread ;) Louis |
^^^ glad you answered your own question. lol
Good 'ol Google. :cool:
| All times are GMT -4. The time now is 09:33 AM. |
