I'm thinking I should start a build thread. Guess this is it.
Old 08-05-2016, 04:50 PM
South Central *********
JapEatr's Avatar
that looks good!
Old 08-05-2016, 04:53 PM
tomj77's Avatar
Originally Posted by JapEatr
that looks good!
The secrat is rocker guard . Shhhhhh
Old 08-06-2016, 04:42 PM
tomj77's Avatar
Got my first batch of parts today. Pictures will come later .
63 Nova SS (08-06-2016)
Old 08-06-2016, 10:58 PM
tomj77's Avatar
Got in my first order of parts today. Here are a few. Not in pic , new set of opels, and some odds and ends like gaskets and trans parts
Old 08-07-2016, 12:43 AM
tomj77's Avatar
my finished dash pod project. turned out awesome
https://www.youtube.com/watch?v=oXHe...ature=youtu.be
Old 08-07-2016, 08:41 PM
tomj77's Avatar
Oh it looks nice with the black trim I also painted
Old 08-07-2016, 08:57 PM
Damn man that looks amazing! Did you paint it? Looks glozier
tomj77 (08-23-2016)
Old 08-07-2016, 10:03 PM
tomj77's Avatar
ya I painted it black. if I just leave it the color of the rocker guard it looks basically like stock color, but its a dust magnet and a little rough. gotta lightly sand with like 800 grit and then paint. I did use a pretty dark semi gloss black though. but it doesn't look as glossy in person. flash adds gloss. lol
Old 08-07-2016, 10:06 PM
tomj77's Avatar
only thing I don't like is the gauges basically touch the dash. I could have moved the pod a little higher or not built it up as high where the gauges sit. I forgot to use my biggest gauge to check, I used one of glowshift gauges, which fit perfectly. also that pod isn't the best looking, but its basically the only one I could find that would work for how I wanted to do it. there is a little to much blank space between the gauges for my liking. but its still looks ALOT better than what I had built last time. if you wanna try this snail, just let me know and ill let u know how I did it.
Old 08-07-2016, 10:19 PM
Let me know tom it should help alot
Old 08-08-2016, 12:08 AM
  #36
tomj77's Avatar
wanna know the pod I used as well? just for reference on how I started?
Old 08-08-2016, 07:28 AM
  #37
Yeah that would help out alot
Old 09-04-2016, 01:11 AM
  #38
tomj77's Avatar
So a few things came in today, so I threw them on my old engine so I could see what needs modifying and measure out some vac lines. I'm using all an4 braided nylon vac lines. want it looking pretty. just need my wastegate now so I can finish.
Old 09-04-2016, 07:33 AM
  #39
63 Nova SS's Avatar
You going with ZZP coils? Setup looks good. Btw thanks for packing the box well, it arrived in great shape.
Old 09-04-2016, 10:05 AM
  #40
tomj77's Avatar
Yup i am. See how they work. Ur welcome. Its gonna look even better once my nylon lines come and my wastegate. Also gotta mod the intake to take an an fitting for oil seperator and exhaust mani for egt
Old 09-15-2016, 09:41 AM
  #41
Ecotecftw's Avatar
Looks good man, coming along nicely!
Old 09-15-2016, 10:51 AM
  #42
colodude18's Avatar
Are the new ZZP coils in stock again? They still owe me my replacement as I purchased them last year before the recall...I'm still running my stocks for now.
Old 09-15-2016, 11:09 AM
  #43
Scythe_Snake's Avatar
They've been in stock for quite a few weeks at this point. :-)
We made an announcement on our FB page and instagram too. shoot customerservice@zzperformance.com
Old 09-15-2016, 01:19 PM
  #44
tomj77's Avatar
I got these a few weeks ago so ya they are
Old 09-15-2016, 01:25 PM
  #45
tomj77's Avatar
Saturday i get the rest of my hoses and wastegate. All i need now is my custom drain hose, braided stainless, then all thats left is flywheel, clutch and motor. I can get the flywheel and clutch bolted to the motor when u guys build it scythe snake yes?
Old 09-15-2016, 01:26 PM
  #46
colodude18's Avatar
Cool I asked about a month (or two?) ago and then was told not yet. I'll shoot customer service an email!
Old 09-15-2016, 01:29 PM
  #47
tomj77's Avatar
Gonna finish up my meth setup and then take some pics, trunk mount with 2.25 devils own tank, stainless braided line till the failsafe gauge flow sensor and normal hose , slipped into an6 braided nylon hose to the nozzel. Id go braided stainless all the way but i can only use a snow holder on the tb spaces plate i modified to actually work properly. So the last few inches is the nylon hose
Old 09-18-2016, 07:39 PM
  #48
tomj77's Avatar
Turbo setup 99% complete. Used braided nylon lines for all the boost lines. Running a meth failsafe so i got a few lines in there. Had to do some mods, the pcv fitting on the manifold keeps the wastegate from fitting so that has to be removed and the port tapped and a 90 degree 1/8 npt to 3/8 barb fitting installed. Oddly enough i had one so that saved me a few bucks. Just need 3 more banjo fittings for a few of my lines to fit the way i want
Braided nylon lines for all the vac lines , looks mint
Old 09-18-2016, 09:48 PM
  #49
63 Nova SS's Avatar
surprised you weren't on opels already? Motor looks good
Old 09-18-2016, 10:05 PM
  #50
tomj77's Avatar
I was on opels
Quick Reply: I'm thinking I should start a build thread. Guess this is it.
