I'm thinking I should start a build thread. Guess this is it.
#756
I sure did. Actually came with some ring which I dont know what it is for but halo fit perfectly on it and is sandwiched between shroud and projector mounting bracket. All holes lined up perfect. 4 screws and it all screwed together. I used epoxy to glue halo to ring and used halo mointing wire at 4 points. Good strong build
#759
Great build, Just spent about 2 hours reading through the thread lol Gnarley arm...
Will definitely be interested in this 6 spd F35 setup if/when my 4.45 F35 decides to **** the bed. Where in Canada are you Tom? Would like to see this beast in action. I'm not far from John myself.
#761
Are these the ones people are using?
https://www.ebay.com/i/152536768370?chn=ps
#762
#771
Kolt (08-01-2018)
#775
You mind expanding on this a bit? I once went for a dyno run on a loaded mustang dyno and the readings were weird for my setup. My torque peaked and died off way earlier than would be expected. We could have been a little off when we calibrated the dyno to engine rpm and I don't know if that by itself could have caused it or not. But you sound like you're familiar with dyno's reading funny so I wondered if you kind of knew what all could cause that to happen.
