I'm thinking I should start a build thread. Guess this is it.
Old 10-26-2018, 02:11 PM
  #826
tomj77's Avatar
Originally Posted by Snail_SS
Tom do you think that I would need that I'm pretty much FBO with ZFR and running e47 maybe one day I'll do e85
are u running Powell v3?
Old 10-26-2018, 03:23 PM
  #827
Nope I was planning on getting one but that money is long gone now lol
Old 10-26-2018, 04:07 PM
  #828
tomj77's Avatar
It be nice to know how it is stock. Warm ur car and tie a rubber glove aroubd open dipstick tube. See if it blows up or not
Old 10-26-2018, 05:36 PM
  #829
Once it's running I'll give it a try and see what happens
Old 11-07-2018, 08:17 PM
  #830
tomj77's Avatar
ok so a few updates. had some maf issues...basically maf was dead. so after hours of checking wires and new sensor....and buying a new ecu dammit. I asked on facebook and apparently the maf runs through the exhaust emissions fuse....I didn't even know there was one. which had blown causing my maf to not work. so now that's fixed lol. I got a second ecu now....for E I guess.
still working on my oil catch can system. I drilled out all my fittings so they are a big as I can get em. also the 1/8 npt fittings for valve cover.... the one of passenger side I drilled out... now its size of stock port. the second one I will be drilling out valve cover hole and putting in a slightly drilled out 1/4 npt to an6, which will then match the stock port size, so no small ass 1/8 npt holes.
I discovered my system is actually pulling too much vacuum, something in my motor sounds like a turkey call cause it is creating so much suction inside the motor. no clue why. u have to take oil cap off so its not sealed and putting so much suction on whatever it is that is making the sound. but as soon as u cover hole with ur hand, u fell it sucking good and it starts growning again. so im gotta get the ttr stock pcv cartrage with stock pcv valve, which should limit the vacuum to stock and solve that issue. the system should work very well then. it works as it is, except for the god awful sound it makes lol.
Old 12-23-2018, 10:27 AM
  #831
tomj77's Avatar
Well I finally got my pcv catch can system working at idle like it should. I'll post a pic later since its not letting me now. Now I need to hook up a gauge to my crank case to see whats going on at wot.
Old 12-23-2018, 01:48 PM
  #832
63 Nova SS's Avatar
Good deal, be interested to see what's going on with the crankcase also.
Old 12-23-2018, 02:53 PM
  #833
Nice Tom! In for results for sure I want to get a system that works properly for sure
Old 12-23-2018, 08:26 PM
  #834
tomj77's Avatar
Snail_SS (12-23-2018)
Old 12-26-2018, 11:05 PM
  #835
tomj77's Avatar
ordered a vac/boost gauge to hook up to crank case via dipstick tube with an4 port on it. so I will be monitoring pressure to see if this catch can system works under boost. hoping to see vac at boost if it works how I want it too. Wont be able to check that till spring I guess. For now just vac at idle.
Old 12-27-2018, 06:58 AM
  #836
63 Nova SS's Avatar
Winter sucks, but at least you can't break anything.
Old 12-27-2018, 08:54 PM
  #837
tomj77's Avatar
sounds like a challenge lol
Old 12-31-2018, 12:08 PM
  #838
cw383's Avatar
Whats it like driving that car with the long first gear? : )
Old 01-05-2019, 01:19 AM
  #839
tomj77's Avatar
its awesome in town in parking lots and such
Old 01-05-2019, 01:23 AM
  #840
tomj77's Avatar
A little catch can system update. Well its done but I still gotta do some testing under boost. I installed a boost gauge to crank case via the port on my old oil sperator dipstick oil drain back, and at idle instead of getting positive pressure I now get -1 vac. It holds stead and does not fluctuate. So solved that issue.
Snail_SS (01-05-2019)
Old 03-18-2019, 11:06 PM
  #841
tomj77's Avatar
I need to update this lol got some coming with my direct port setup from prometh
Old 03-19-2019, 08:11 AM
  #842
jdbaugh1's Avatar
What's that look like?
Old 03-19-2019, 08:10 PM
  #843
tomj77's Avatar
The following 3 users liked this post by tomj77:
jdbaugh1 (03-19-2019), Snail_SS (03-19-2019), victory_red_SS (04-09-2019)
Old 03-19-2019, 08:20 PM
  #844
jdbaugh1's Avatar
Damn that looks nice.
Old 03-19-2019, 08:35 PM
  #845
Damn that looks clean, very nice install of the kit.
Old 03-19-2019, 08:54 PM
  #846
tomj77's Avatar
Trying to upload pic of it on the car but it doesnt work. Im waiting for a few fittings yet. A short line goes to a solenoid mounted on the fuel pump bracket, then down to flow meter and filter. Ill post it when its done.
Running 2gph per cylinder.
Old 03-19-2019, 11:15 PM
  #847
Damn that's amazing! I would love to have that
Old 03-20-2019, 06:18 AM
  #848
jdbaugh1's Avatar
Straight methanol or what? Will it have variable flow or just on/off?
Old 03-20-2019, 07:41 AM
  #849
tomj77's Avatar
prometh.com. they do awesome work and have alot of stuff places like devils own dont. And they actually care. The guy will straight up phone you and discuss your setup and exactly what your looking for and make it from there. They dont use metal line ends so no rusting, and they communicate till you are satisfied. Check em out.
Snail_SS (03-20-2019)
Old 03-20-2019, 07:44 AM
  #850
tomj77's Avatar
no its 50 50. And progressive , i still got the snow controller and devils own pump. Gonna slowly change them to prometh though . they got way better stuff. They got like 5 different pumps supporting up to 1600hp. They make stuff for race teams. Check them out. Got lots of little things id been looking for. Like mini check valves. If you look at the pic, its got 2 of them , one per 2 cylinders.
Quick Reply: I'm thinking I should start a build thread. Guess this is it.
