that looks good!
Originally Posted by JapEatr
(Post 7617361)
that looks good!
Got my first batch of parts today. Pictures will come later .
Got in my first order of parts today. Here are a few. Not in pic , new set of opels, and some odds and ends like gaskets and trans parts
https://cimg7.ibsrv.net/gimg/www.cob...cf6a238db.jpeg |
my finished dash pod project. turned out awesome
https://www.youtube.com/watch?v=oXHe...ature=youtu.be |
Oh it looks nice with the black trim I also painted
https://cimg4.ibsrv.net/gimg/www.cob...11c1cd360.jpeg |
Damn man that looks amazing! Did you paint it? Looks glozier
Originally Posted by Snail_SS
(Post 7617542)
only thing I don't like is the gauges basically touch the dash. I could have moved the pod a little higher or not built it up as high where the gauges sit. I forgot to use my biggest gauge to check, I used one of glowshift gauges, which fit perfectly. also that pod isn't the best looking, but its basically the only one I could find that would work for how I wanted to do it. there is a little to much blank space between the gauges for my liking. but its still looks ALOT better than what I had built last time. if you wanna try this snail, just let me know and ill let u know how I did it.
Let me know tom it should help alot
(Post 7617558)
Yeah that would help out alot
So a few things came in today, so I threw them on my old engine so I could see what needs modifying and measure out some vac lines. I'm using all an4 braided nylon vac lines. want it looking pretty. just need my wastegate now so I can finish.
https://cimg2.ibsrv.net/gimg/www.cob...e153e27585.jpg https://cimg3.ibsrv.net/gimg/www.cob...2e7daf01ec.jpg https://cimg4.ibsrv.net/gimg/www.cob...a2388e7520.jpg |
Originally Posted by tomj77
(Post 7621207)
(Post 7621214)
You going with ZZP coils? Setup looks good. Btw thanks for packing the box well, it arrived in great shape.
Looks good man, coming along nicely!
Are the new ZZP coils in stock again? They still owe me my replacement as I purchased them last year before the recall...I'm still running my stocks for now.
(Post 7622409)
We made an announcement on our FB page and instagram too. shoot customerservice@zzperformance.com |
(Post 7622409)
Saturday i get the rest of my hoses and wastegate. All i need now is my custom drain hose, braided stainless, then all thats left is flywheel, clutch and motor. I can get the flywheel and clutch bolted to the motor when u guys build it scythe snake yes?
Originally Posted by Scythe_Snake
(Post 7622414)
They've been in stock for quite a few weeks at this point. :-)
Gonna finish up my meth setup and then take some pics, trunk mount with 2.25 devils own tank, stainless braided line till the failsafe gauge flow sensor and normal hose , slipped into an6 braided nylon hose to the nozzel. Id go braided stainless all the way but i can only use a snow holder on the tb spaces plate i modified to actually work properly. So the last few inches is the nylon hose
https://cimg3.ibsrv.net/gimg/www.cob...ad9525d623.jpg
Turbo setup 99% complete. Used braided nylon lines for all the boost lines. Running a meth failsafe so i got a few lines in there. Had to do some mods, the pcv fitting on the manifold keeps the wastegate from fitting so that has to be removed and the port tapped and a 90 degree 1/8 npt to 3/8 barb fitting installed. Oddly enough i had one so that saved me a few bucks. Just need 3 more banjo fittings for a few of my lines to fit the way i want https://cimg6.ibsrv.net/gimg/www.cob...f5ff7d2107.jpg Braided nylon lines for all the vac lines , looks mint |
surprised you weren't on opels already? Motor looks good
I was on opels
