I'm thinking I should start a build thread. Guess this is it.
#333
I know of parameters you can monitor I just wondered what all he was monitoring. You could cover a lot of those with a single tablet or smart phone and a bluetooth OBDII adapter. I personally monitor AFR, IAT2, boost, and keep the coolant temp up on the dash. I would like to do a gauge for oil pressure and maybe even oil temp. But even after that Tom would have 3 more gauges lol so I was just wondering what all he was monitoring out of curiosity.
#337
I monitor oil temp and pressure, fuel rail pressure, stft ltft, knock, afr, meth failsafe, boost, coolant temp, exhaust gas temp and the volts is just cause I had an open pod. And yes I built the dash , thats my third attempt, first 2 sucked lol
#345
Almost got it all done. Waiting for new oil line junk, a fitting and some stuff from Powell. Filled with oil and coolant , will finish coolant when I can start get. Almost done bleed brakes but one of the rear bleeder screws didn't wanna come out so had to order new one since I destroyed it, gonna be a little work getting old one out
Shes almost done.
Looks so good.
Shes almost done.
Looks so good.
#346
Does anyone else have a real hard time plugging the rad fans in? I push the connectors as hard as I can and it will not click in. Although I looked at the fan and it seems where the connector should clip in looks broken. But ya every time I have to do this it takes forever to get them in. At this point it's in real right but not locked so I'm guessing over time I'm gonna have to go under and do it again. That or buy new fans . pisses me off a little
