I'm thinking I should start a build thread. Guess this is it. - Page 2 - Cobalt SS Network
Go Back  Cobalt SS Network > Engine Technical Discussion > 2.0L LNF Performance Tech
I'm thinking I should start a build thread. Guess this is it. >
Old 08-05-2016, 05:50 PM
South Central *********
that looks good!
JapEatr is offline
Old 08-05-2016, 05:53 PM
Originally Posted by JapEatr View Post
that looks good!
The secrat is rocker guard . Shhhhhh
tomj77 is offline
Old 08-06-2016, 05:42 PM
Got my first batch of parts today. Pictures will come later .
tomj77 is offline
The Following User Says Thank You to tomj77 For This Useful Post:
63 Nova SS (08-06-2016)
Old 08-06-2016, 11:58 PM
Got in my first order of parts today. Here are a few. Not in pic , new set of opels, and some odds and ends like gaskets and trans parts
tomj77 is offline
Old 08-07-2016, 01:43 AM
my finished dash pod project. turned out awesome
https://www.youtube.com/watch?v=oXHe...ature=youtu.be
tomj77 is offline
Old 08-07-2016, 09:41 PM
Oh it looks nice with the black trim I also painted
tomj77 is offline
Old 08-07-2016, 09:57 PM
Damn man that looks amazing! Did you paint it? Looks glozier
Snail_SS is offline
The Following User Says Thank You to Snail_SS For This Useful Post:
tomj77 (08-23-2016)
Old 08-07-2016, 11:03 PM
ya I painted it black. if I just leave it the color of the rocker guard it looks basically like stock color, but its a dust magnet and a little rough. gotta lightly sand with like 800 grit and then paint. I did use a pretty dark semi gloss black though. but it doesn't look as glossy in person. flash adds gloss. lol
tomj77 is offline
Old 08-07-2016, 11:06 PM
only thing I don't like is the gauges basically touch the dash. I could have moved the pod a little higher or not built it up as high where the gauges sit. I forgot to use my biggest gauge to check, I used one of glowshift gauges, which fit perfectly. also that pod isn't the best looking, but its basically the only one I could find that would work for how I wanted to do it. there is a little to much blank space between the gauges for my liking. but its still looks ALOT better than what I had built last time. if you wanna try this snail, just let me know and ill let u know how I did it.
tomj77 is offline
Old 08-07-2016, 11:19 PM
Let me know tom it should help alot
Snail_SS is offline
Old 08-08-2016, 01:08 AM
  #36
wanna know the pod I used as well? just for reference on how I started?
tomj77 is offline
Old 08-08-2016, 08:28 AM
  #37
Yeah that would help out alot
Snail_SS is offline
Old 09-04-2016, 02:11 AM
  #38
So a few things came in today, so I threw them on my old engine so I could see what needs modifying and measure out some vac lines. I'm using all an4 braided nylon vac lines. want it looking pretty. just need my wastegate now so I can finish.
tomj77 is offline
Old 09-04-2016, 08:33 AM
  #39
You going with ZZP coils? Setup looks good. Btw thanks for packing the box well, it arrived in great shape.
63 Nova SS is offline
Old 09-04-2016, 11:05 AM
  #40
Yup i am. See how they work. Ur welcome. Its gonna look even better once my nylon lines come and my wastegate. Also gotta mod the intake to take an an fitting for oil seperator and exhaust mani for egt
tomj77 is offline
Old 09-15-2016, 10:41 AM
  #41
Looks good man, coming along nicely!
Ecotecftw is offline
Old 09-15-2016, 11:51 AM
  #42
Are the new ZZP coils in stock again? They still owe me my replacement as I purchased them last year before the recall...I'm still running my stocks for now.
colodude18 is offline
Old 09-15-2016, 12:09 PM
  #43
Scythe_Snake's Avatar
They've been in stock for quite a few weeks at this point. :-)
We made an announcement on our FB page and instagram too. shoot [email protected]
Scythe_Snake is offline
Old 09-15-2016, 02:19 PM
  #44
I got these a few weeks ago so ya they are
tomj77 is offline
Old 09-15-2016, 02:25 PM
  #45
Saturday i get the rest of my hoses and wastegate. All i need now is my custom drain hose, braided stainless, then all thats left is flywheel, clutch and motor. I can get the flywheel and clutch bolted to the motor when u guys build it scythe snake yes?
tomj77 is offline
Old 09-15-2016, 02:26 PM
  #46
Cool I asked about a month (or two?) ago and then was told not yet. I'll shoot customer service an email!
Old 09-15-2016, 02:29 PM
  #47
Gonna finish up my meth setup and then take some pics, trunk mount with 2.25 devils own tank, stainless braided line till the failsafe gauge flow sensor and normal hose , slipped into an6 braided nylon hose to the nozzel. Id go braided stainless all the way but i can only use a snow holder on the tb spaces plate i modified to actually work properly. So the last few inches is the nylon hose
tomj77 is offline
Old 09-18-2016, 08:39 PM
  #48
Turbo setup 99% complete. Used braided nylon lines for all the boost lines. Running a meth failsafe so i got a few lines in there. Had to do some mods, the pcv fitting on the manifold keeps the wastegate from fitting so that has to be removed and the port tapped and a 90 degree 1/8 npt to 3/8 barb fitting installed. Oddly enough i had one so that saved me a few bucks. Just need 3 more banjo fittings for a few of my lines to fit the way i want
Braided nylon lines for all the vac lines , looks mint
tomj77 is offline
Old 09-18-2016, 10:48 PM
  #49
surprised you weren't on opels already? Motor looks good
Old 09-18-2016, 11:05 PM
  #50
I was on opels
tomj77 is offline
Quick Reply: I'm thinking I should start a build thread. Guess this is it.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
