So there is no need for walnut shit going everywhere? This is good news
Originally Posted by ThoR294
(Post 7626312)
Originally Posted by Tdubbs
The walnut blasting is still going to produce the best results. You can get good results with just cleaners, but expect to spend some more time per cylinder to get a result worth the effort.
Originally Posted by no_ss
(Post 7626322)
The only benefit of walnut blasting is faster process. You can get just as clean with cleaners and picks.
cleaning up the walnut shells may take longer LOL. plus, I have a friend with me so we can tackle 2 cylinders at once.
It's really not that big of a mess if you blast for a bit then vacuum out, and while you're blasting hold the vacuum line near the intake runner you're blasting. Then after you get done you'll have a bit to vacuum around the engine bay depending on how well you taped everything off, and some on the floor that you'll keep finding for awhile
Originally Posted by ECaulk
(Post 7626341)
So for those who soak overnight, do you soak 3 cylinders one night and then the 4th cylinder the next night? I thought you couldn't get all valves closed at the same time.
Originally Posted by Solaris99
(Post 7626346)
I guess soak over night, soak up cleaner in morning out of 3 cylinders, rotate engine, start soaking other cylinder while cleaning other cylinders. |
I have like 5 methods of transportation (see sig), so downtime isn't a big thing for me hahaha
Cleaner washing the oil film from the cylinder walls is a worry I'd have.
(Post 7626379)
If your valve seats are bad you would likely be seeing other issues. |
Originally Posted by umrdyldo
(Post 7626381)
As far as i could tell the 3 cylinders have valves that are closed. If your valve seats are good, then the fluid should not leak into the cylinder.
yeah the solvent really wasn't as useful as the walnut blasting
I didn't soak overnight. No need to.
I also cranked engine over for a second for the last 2 valves to clean them. Very easy. Don't overthink it.
(Post 7626459)
Originally Posted by double clutch
(Post 7626470)
Your making me not dread this job as much. I thought it was gonna be awful
the job itself is easy.
(Post 7626519)
I need to clean my valves again, but dread it. For no reason really. I'll probably just soak mine with BG 44K instead of screwing with walnut shells everywhere. |
when we did my car and Ecaulks, I don't have a lift. However the Lower CP is a bitch to remove. I cut mine in half to make it easier to remove.
I just took removed my coupler from my throttle body, didn't remove the charge pipe at all, just plugged it with a rag. But I also don't know why you guys have such a hard time with the lower charge pipe. I didn't have a problem at all when I removed my stock and installed my new one. I didn't use a lift.
4 Attachment(s)
At about 95,300 miles now and time to clean the valves again. I'll repost original images in the thread since the links are no good.
When I first took on the valves at 72,818 miles. 53k had no air/oil separator and the rest was with Powell's version 2 (no PCV mod) Attachment 62656 My lousy attempt at cleaning Attachment 62657 What they look like after 23k more miles Attachment 62658 My better attempt at cleaning Attachment 62659 Haven't driven it yet. I'll put it back together tomorrow. I used carburetor cleaner this time with picks and cotton swabs. The carb cleaner melted the carbon off. I didn't let the ports soak extremely long, maybe 5 minutes each time. I soaked them at least 3-4 times. I'm happy I got them this clean, but I'm disturbed by how much oil has accumulated even with the air/oil separator. I got cylinder 4 misfires the other morning with high RPM high load. The spark plug looked great and I think this carbon was the reason. It was bad on that cylinder, too. I'll upgrade to Powell's newest version of the air/oil separator if it'll prevent this. It's saddening to have this as regular maintenance. |
I hate to break it to you, but I had powell V3 (the one that modifies the PCV stuff) and it looked marginally better, but I had 10k less miles. And we're not alone.
I recently swapped an LDK into my car and decided against PCV changes. I'd rather run the stock pcv and clean after 30-40k than constantly worry about a complicated setup and leaks and filters etc etc. There's tons of GM cars out there with no solution for this, I think being proactive in cleaning is the only true solution (without getting into custom multi can setups). Simplicity > all else. Mine's a DD, I feel much better not worrying about it. Also, GM Top Engine Cleaner works wonders, costs $17 on amazon, and you shouldn't use the whole can (I didn't when I cleaned mine at 113k miles). I rinse with carb cleaner but didn't feel comfortable cleaning with it around valve seals. |
I am just going to plan to do this every 2 years. I'll get some of that GM cleaner for next time so I can safely submerge the entire valve. I didn't completely fill the ports with carb cleaner and the seals weren't submerged. I'd like to see a 5th injector solution, but that's going to be another costly approach.
