Intercooler??
Old Apr 9, 2020 | 08:02 PM
CobaltSS313's Avatar
Intercooler??
Looking to purchase an aftermarket intercooler. Any recommendations? Hahn or ZZP? Any feedback is helpful.
Old Apr 11, 2020 | 11:54 AM
DeanSsspsh's Avatar
ZZP/fmic & there charge pipes & couplers all day everyday. I got the standard size. I'm on POWELL YYZ Springs & am not lowered. If i go straight out of driveways i do bottom out so you have to do the sideways exit thing unless you buy there smaller version for clearance(another 1/2 inch) I had a cracked end tank & a leak @ the seam of the lower charge pipe. I epoxied it with good success but was loosing my mind chasing a vacuum leak(pcv valve in intake mani wasn't checking). I've bottomed out like 10 times so far with no problems.The intercooler practically likes the abuse. Car definitely runs cooler as well. ZZP no further questions.
Old Apr 16, 2020 | 10:59 AM
C0balts5's Avatar
I run the modern performance one and re drilled holes a half of an inch below the existing holes and got more ground clearance than the factory
Old Apr 16, 2020 | 03:02 PM
Zzp
Old Apr 16, 2020 | 09:37 PM
califcarm's Avatar
I went zzp standard size with upper charge pipe from them. (Blew apart my stock plastic units). Very happy with both zzp pcs. I went standard size (stock size) iC as I did not want to worry about bottoming out on the bigger one. I would think 400whp and under should do just fine on this IC.
SexySS
Dec 28, 2013 05:53 PM
lil-red-89
May 3, 2012 09:38 AM
domestic_rice
Dec 16, 2011 05:52 PM
Gixxercobaltdriver
Mar 30, 2011 02:48 PM
CRR
Jul 9, 2010 03:52 PM
