K04 mod to make it last longer ?
Old Sep 27, 2015 | 03:35 PM
OPCrer's Avatar
My tuner said that tuning the LNF K04 with a peak boost of 25psi will reduce the turbo life span dramatically.
Is it possible to make low cost upgrade to the stock turbo to make it stronger ? don't want to spend a fortune on a bigger turbo, just some money to give a longer life span.. better bearings, don't know..
Old Sep 27, 2015 | 06:39 PM
tomj77's Avatar
Stay 24psi and under on stock turbo cause ur past its efficiency anyway at that point and producing a lot of hot air, u won't gain much performance past 24 due to this. I doubt it will reduce its life as drematically as ur tuner implies, but still keep it a little lower. U can do a big wheel upgrade on it, that would help. Get k04r I believe it is.
Old Sep 27, 2015 | 06:47 PM
footballplaya3k's Avatar
Less boost will make it last longer.
Old Sep 27, 2015 | 08:11 PM
nathan112i's Avatar
as stated above k04R, its a great turbo i had one
06MetallicBalt
Jul 20, 2025 08:47 PM
dennis69
Oct 20, 2015 04:49 PM
Stuff
Oct 1, 2015 05:47 PM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
