LDK Cobalt SS only boost 5 psi
Hello guys, got a cobalt ss with the ldk engine. Swapped turbos to 5858 pte and car doesn't built pass 5 psi. You go wot and car pushes 5 psi then falls flat on its face to 0 psi!
we've changed wastegates, bovs, done boost leak tests and can't find something bad!
any help?
thanks!
any help?
thanks!
run manifold pressure line straight to wastegate and see what happens be careful and watch the boost gauge too.. if you get full boost then its probably in limp mode or a bad boost solinoid
any help?
thanks!
any help?
thanks!
SFloyd80
03-16-2015 11:07 AM
