Leaking oil under HPFP
I saw the thread about this being a common problem, but in that thread he says there is an O ring for the HPFP. or at least thats how I read it. well my cobalt started leaking oil probably 2 days ago and I just noticed it got low. Found out it was the HPFP.
I just want to make sure there is no Oring besides the gasket that mates the HPFP To the block, cause I sure cant find one
I thought it was a cam cap seal?
EDIT: There's a PIP from GM about it and a TSB.
#PIP4739: Oil Leak In High Pressure Fuel pump Area 2007-10 Ecotec (RPO LNF) - (Nov 9, 2009)
Subject:
Oil Leak in High Pressure Fuel Pump Area 2007-10 Ecotec (RPO-LNF)
Models:
2008-2010 Chevrolet Cobalt SS Only
2008-2010 Chevrolet HHR SS Only
2007-2010 Pontiac Solstice GXP
2007-2010 Saturn Sky Redline
With 2.0L Engine RPO LNF Only
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A technician may comment of an oil leak in the high pressure fuel pump area.
Recommendation/Instructions:
Engineering has determined that an oil leak in this area is most likely coming from the #6 intake cam cap at the high pressure fuel pump. To repair this concern the technician should reseal the cam cap. Follow eSI procedure under "Engine | Engine Mechanical - 2.0L | Repair Instructions - On Vehicle | Intake Camshaft and Valve Lifter Replacement " for repair instructions and specific locations to apply sealer for the #6 cap.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
__________________________________________________ _________________
TSB: #09-06-01-014: Oil Leak by High Pressure Fuel Pump (Reseal Camshaft Cap) - (Dec 3, 2009)
Subject:
Models:
2007-2009 Chevrolet Cobalt SS, HHR SS
2007-2009 Pontiac Solstice GXP
2007-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
Equipped with a RPO LNF Engine
Please Refer to GMVIS
Condition
Some customers may comment on an oil leak.
Upon further investigation, a technician may find oil leaking from the high pressure fuel pump area.
Cause
This condition may be caused by a camshaft cap that is not sealed correctly to the cylinder head, causing oil to leak out.
Subject:
Models:
Condition/Concern:
Subject:
Models:
2008-2009 Opel GT
2008 Daewoo G2X
Condition
Cause
Parts list per the TSB:
12609291 Camshaft Cover Gasket
12595951 Gasket, High Pressure Fuel Pump Gasket
12600313 High Pressure Fuel Pump O-Ring
12615401 High Pressure Fuel Pipe
Another thing that I would recommend while your doing this. When taking the HPFP housing off you will see that the silicon sealant that GM had applied during production of these engines on the housing is laughable and explains some oil leakage. Here is a picture:
You can see on this pic how with the little silicon that was applied from the factory where the oil was leaking through.
This was after we had coated it with a sufficient amount silicon sealant
Re-installed
Coating the sides
So upon getting the Gasket for the HPFP and the Oring for the cap i would apply the silicon sealant on the housing as per the pictures. I did this and I haven't had a problem since.
Re-installed
Coating the sides
Good info. Thanks 40rty
Looks like so far I stopped the leak. I left the car for 12 hours to fully cure the RTV and put a cardboard piece under my car to see if it leaked. It hasn't had 1 drop so far.
Glad this didnt happen when I was getting tuned, my oil was low so it had to have been doing it for awhile
Not really. Remove the two bolts holding the HPFP in and the fuel lines that go into it. IIRC a 17mm wrench works. Then take it off and put it somewhere safe. Also, make sure to have your fuel pump fuse taken out and you start the car to remove any excess fuel so you dont get fuel everywhere but some will leak out. I just put a towel under it.
I just replaced my hpfp yesterday and it was pretty easy to remove as long as you can get your hands in there to remove the black plate in front of it.. Mine was leaking all over the place, but i didnt notice it was coming from the housing like 40rty was. Damn, now im gonna wonder if i need to reseal it as well.
My car had a leak that was puddling up under the HPFP too, I thought for sure it was this problem, but mine was my rear main seal. Got it replaced under warranty and hasn't leaked a drop since haha.
No idea, started leaking oil not long after I bought the car and I just kept putting oil in it for a few weeks then I took it to the dealer and they said that was my problem, no leak since.
Back from the dead. So I just finished fixing this annoying leak and was wondering if any of you actually replaced the fuel line? The thing is 50 bucks so I contemplating whether or not run the risk of my car setting ablaze. I also noticed that the fuel feed line also says it needs to be replaced after its been removed. Part number 12636128
Any input would be appreciated!
Check the how to on this, don't just replace gaskets, it will leak again. In fact for the cam cover u don't even use a gasket to do it right. Fill the gasket grove with rtv, squish it in there good then put another bead on top of that, won't ever leak again
ampzor350 (03-22-2016)
