Lets Beat it with a Stick more...ZFR vs. WR-2
Hey man, my turbo is full spool by roughy 4k. I know that is a bit laggy but it's not too bad. I have a nice power curve and at 7k the power is still coming in. The main difference between the 2 and 3 are the size (obviously) with the wr-2 you have a 51mm comp wheel and a 56.5mm exhaust turbine. With the 3 you have a 55mm compressor wheel. You also have the option of the 4" inlet and 2.5"outlet. They give you the option of getting it with the forge bypass valve. and you can also have your compressor cover powdercoated
robk
QuickSilver_SS
09-17-2015 05:38 PM
