limp mode??
Old Aug 22, 2011 | 05:55 PM
domestic_rice's Avatar
limp mode??
once or twice a week now my car will only boost up to 5 psi and then i get compresser surge and the bypass dosnt open up here are my mods any thoughts
gms1
3 inch cia dp
3 inch exaust
dejon charge pipe hot side
dejon short ram intake
hks bov (running both)
is this just a senerio telling me i need a better tune?
Old Aug 22, 2011 | 09:47 PM
MS3 2 SSTC's Avatar
I'm guessing it's the GMS1, lower charge pipe sensor. It's either loose or the dealer didn't solder the wires.
Old Aug 22, 2011 | 09:49 PM
HB_SS/TC's Avatar
gms1
3 inch cia dp
3 inch exaust
did you get retuned for these?
Old Aug 22, 2011 | 10:12 PM
no i didnt im starting to think i have enought mods that i need a tune considering my air fuel mixture goes nuts everyday ranges from 12-17 normal driving up and down up and down
Old Aug 22, 2011 | 10:14 PM
i will take a look at this tomorrow thanks!
Old Aug 23, 2011 | 12:04 AM
BYT*SS*TURBO's Avatar
Some of the older Dejon Intake that Ive seen didn't have the proper Breather Fitting on it and the hose just sat on there. If that comes off it will create a Post MAF Airleak and cause issues.
If you want to run the BOV with the least amount of issues, you should consider doing a MAF relocate and getting a real tune for the car. It is possible to leave it in the stock location and tune it but it's better with the relocate. You CAN NOT do a MAF relocate without a real tune, don't even try it!
Old Aug 23, 2011 | 12:12 AM
dayhoff35's Avatar
check the sensors first they could be going bad or have a loose connection
Old Aug 23, 2011 | 12:46 AM
MS3 2 SSTC's Avatar
I had this issue too. My AFR would bounce like a set of double Ds in a **** movie and it was driving me crazy. The car would buck like a bull at a PBR show.... anyways I took it in at the dealer and they soldered the wires and relocated them to run just above the AC line to prevent dondensation from dripping on them. Two weeks since they fixed the lower charge pipe sensor by soldering it and I've had no issues. If you do end up taking it in to the dealer tell them to solder the wires and to relocate them to run above the AC line. Worked for me
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
