limp mode??
once or twice a week now my car will only boost up to 5 psi and then i get compresser surge and the bypass dosnt open up here are my mods any thoughts
gms1 3 inch cia dp 3 inch exaust dejon charge pipe hot side dejon short ram intake hks bov (running both) is this just a senerio telling me i need a better tune? |
I'm guessing it's the GMS1, lower charge pipe sensor. It's either loose or the dealer didn't solder the wires.
Originally Posted by domestic_rice
(Post 5999946)
Originally Posted by HB_SS/TC
(Post 6000440)
did you get retuned for these?
Originally Posted by MS3 2 SSTC
(Post 6000432)
Some of the older Dejon Intake that Ive seen didn't have the proper Breather Fitting on it and the hose just sat on there. If that comes off it will create a Post MAF Airleak and cause issues.
If you want to run the BOV with the least amount of issues, you should consider doing a MAF relocate and getting a real tune for the car. It is possible to leave it in the stock location and tune it but it's better with the relocate. You CAN NOT do a MAF relocate without a real tune, don't even try it! |
check the sensors first they could be going bad or have a loose connection
(Post 6000512)
no i didnt im starting to think i have enought mods that i need a tune considering my air fuel mixture goes nuts everyday ranges from 12-17 normal driving up and down up and down
| All times are GMT -4. The time now is 09:57 AM. |
